    Oct 2005
    Europe
    hi all . I am trying to capture some video and be able to publish it on web. I wonder what is the best setting for web video so that size is not huge and the quality is not low. I am using pinnacle studio 10 quick start 10.v. I be happy if some who worked with this sofware give me some guides.Thanks
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    wmv or flv are good web formats. But don't mention "publish on web" and "quality" in the same post..
    /Mats
    Oct 2005
    Europe
    /Mats
    Thank for u reply. could u mention what should be the width and hight and ect... i am using pinnacle studio quick start version 10.7.thanks
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Hard to say, but the smaller the frame size, the lower the bitrate can be used, and the smaller the file will be.
    /Mats
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You can convert to WMV with WMM or WME. Height an width is really relevant to the bitrate you are using. Both have a few presets, WME allows for completely custom presets. Try a fe different ones and tweak them, you can use a pretty large resolution and still get some pretty good quality.
    Here's a 500kbps 640x360, running time is a little over 7 mins, file size is about 27MB's.
    http://www.40lbhead.com/headfiles/albums/video/rockfest2005_empire_wandt.wmv
