Since I put together a new pc I'm having the following problem. I'm
capturing TV shows with a Terratec Cinergy 600 card with a program called
Fly 2000 TV and using the PICVideo v3 MJPEG codec (capturing in DVD quality 720 x 576). This all works fine.
However, when I try to play it back with Media Player 11 via TV out (composite) to my
TV, I cannot get it to play full screen. Also played with the settings in performance, advanced but no change. WINDVD 7 gives the same problem.
I'm using an ASUS EN7600GT PCI-E with 256 MB memory in my pc set to clone
mode with the latest forceware drivers (tried also with 8x drivers). The TV is set as the full screen video device. When I use huffyuv as a codec, the same thing happens. When I render the footage to MPEG2 it plays fine on my tv in full screen. Playing DVD disks also works fine on full screen TV. It looks like the video overlay function does not work correctly with these files.
My previous pc had an ATI 9600XT which played these files just fine in full
screen using TV out.
My system specs:
Win XP SP2 32bit
Intel DP965LT motherboard
Intel E6700 core 2 duo CPU 2,66
2 Gb DDR2 667 memory
Seagate Barracude 120GB SATA2
Seagate Barracude 320GB SATA2
Asus EN7600GT 256 MB
Plextor PX-760SA DVD drive
Results 1 to 1 of 1
video overlay
By Richpress in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 18:05 -
Image Overlay on video
By mediachips in forum EditingReplies: 3Last Post: 25th Aug 2008, 02:59 -
Nvidia latest drivers giving me problems?
By Immortal25 in forum ComputerReplies: 7Last Post: 26th Nov 2007, 20:37 -
PCLinuxOS 2007: Problems with my Nvidia graphics card
By FulciLives in forum LinuxReplies: 24Last Post: 1st Aug 2007, 17:37 -
Nvidia 6800 GT Video Card Problems
By theyuw in forum ComputerReplies: 12Last Post: 2nd Jul 2007, 19:54
