Since i want 2 subtitles on my SVCD i have to mux with I-Author, right? Or is there outher proggs to make selectable subs, if so what and how?
ATM i have a file muxed in I-Authors muxer with subtitles.
Now I want to Author with menus and chapters. Since i find best result easiest comes with TSCV (VCDImager) i would prefere yo use that. But whan i try to make a bin it results in this:
>Starting VCDxBuild process...
>initializing libvcd 0.7.11 [cygwin/i686]
> this is the UNSTABLE development branch!
> use only if you know what you are doing
> see http://www.hvrlab.org/~hvr/vcdimager/ for more >information
>scanning mpeg sequence item "sequence-1" for scanpoints...
>mpeg scan: pack header code (0x000001ba) expected, but >0x01006000 found (buflen = 2324)
>input mpeg stream has been deemed invalid -- aborting
>VCDxBuild finished
so is there any way to convert the mps to a file liked by VCDImager?
vitualis?
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
anyone?
No I don't believe an I-Author created .mps file can be used in anything other than the I-Author program.
There is a new svcd multiplexor which is actually better anyways. Submux, which can be found on the dvd2svcd homepage can create both cvd style as well as svcd style subs, wheareas I-Author can only create the less supported cvd style. Submux is freeware and does appear to still have some bugs. I'm not sure if a final version is out yet but I have had some success with it. It's definitely better to use then I-Author though and you will be able to use your muxed files in vcdimager. -
I have read of 2 possibilities. One thing to try is to check the "PS" check box in the I-Author muxer and after it has finished change the file extension to mpg. I haven't personally gotten this to work. The other possibility that I have gotten to work is to use a program called "SubMux" on the mpg file after you have multiplexed the audio and video. This is being actively discussed on ttolls forum.http://www.ttoolforum.formativ.net/phpBB/viewtopic.php?topic=588&forum=25&21
I think it is also being incorporated into the next version of TSCV. This can put either SVCD or CVD style subtitles into the file.
Author AVCHD from .mov files?
By p_l in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Jan 2011, 21:19 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Need TMPGEnc Author help for .mts files!
By Woodserr in forum Video ConversionReplies: 4Last Post: 13th Jul 2009, 10:09 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
How do I Author an HD-DVD using mkv files....
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 10th Dec 2007, 11:47
