I could use premiere pro 2 without problem, but recently I can't open premiere pro at all.
When I click the premiere pro, then it opens starting premiere pro, saying windows xp single processor detected, then loading Cpm ( can't read because it shut down immediately). then it shut down. never open again !!!
What should I do !!!! I need it for business, so please help me !
I reinstalled premiere pro, but it won't help at all !
Mayuko
Contact the Adobe Customer Support first, and also check out the FAQ's for the software in case there's anything there.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Have you installed any other software since the last time it worked properly?
We had some reports of Premiere Elements shutting down in a similar way after installing one of our products. After a lot of testing and debugging, we identified that Premiere was not responding correctly to our software. We have had to write a "fix" to accommodate this.
(Technically, it has to do with how Premiere determines what codecs are present and what capabilities they have. Each codec is queried. Premiere doesn't correctly handle the responses. I must say I was very surprised - this has been a known issue with Premiere since at least version 4.0).John Miller
Adobe Premiere Pro CS5.5 editting help. It won't let me add any more clips?
By Devilsadvocate in forum EditingReplies: 2Last Post: 28th Feb 2012, 08:55 -
Avsp won't start
By vidalien in forum EditingReplies: 12Last Post: 14th Mar 2010, 17:04 -
Rip won't start
By audax in forum Authoring (DVD)Replies: 3Last Post: 20th Jun 2009, 02:41 -
PC won't start
By DuBsTaR in forum ComputerReplies: 8Last Post: 7th Nov 2008, 23:11 -
Premiere Pro 1.5 Won't Import Any AVI? Zoiks!
By glowing_zebra in forum DVD RippingReplies: 1Last Post: 7th Jul 2007, 04:28
