I have a just bought COBY TF-DVD 7107 thro Amazon. To my shock whichever DVD or MP3 or VCD i put inside IT shows this error . " WRONG DISC" I have also unplugged and used it AFTER several hrs..still the same problem. i have also used Other REGION Disc..stil the same WRONG DISC Msg. Can you pl provide guidance to make it work/playable . TIA
I would exchange it. If it isn't reading any disc, then there is some sort of hardware or firmare issue.
Google is your Friend -
i have a coby as well and recently gave me wrong disk error as well , with any burnt disk , that previously used to play . it would play oringinal disk . i eventually found this to be the problem
the bit that actually spins the disk can actually move to an incorrect position , more likely than not downwards , so putting the disk too close to the lens. I found by having the top level with the steel pin thingy , it would again read all disks . Eventually i super glued this in place . Supplier said it was caused by misabuse so would not cover by warrenty.
sony DVD Recorder RDR-GX257 "unknown disc "msg
By corpjet in forum DVD & Blu-ray RecordersReplies: 2Last Post: 16th Feb 2010, 13:08 -
Coby DVD-288
By manishkumar in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Oct 2009, 23:07 -
coby dvd 283
By bwisittalaga1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Aug 2008, 17:58 -
"wrong disc inserted please insert the cd/dvd"
By SIRCOOKS in forum ComputerReplies: 5Last Post: 14th May 2008, 12:49 -
Help with COBY - DVD 217
By BIFFtheSTIFF in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Aug 2007, 08:52
