Hello,
I know that the Panasonic rv31 can not play svcds. However, I read that this unit can still play mpeg2 videos if burnt with nero and using VCD format. Is this correct? Also, at what resolution and bit rate will work.
I'm sorry if this topic was brought up previously. I'm new to the vcd world.
Thanks in advance,
Chris
Max bitrate of ~2.6 mbps, VCD res of 352x240/480 and 720x480, only works with TMPG mpeg2 video files...or should say only those enocders that allow you to change the VBV buffer size. This player is very picky about the VCD buffer size being around 40 KB. So be sure to change that, TMPG is the only app I have used that allows for this (really hoping the latest version CCE would allow for this).
However, me and many others on this forum are of the opinion that there is no difference tween mpeg1 & mpeg2 at equal resolutions & bitrate. Thus, going out your way to encode an mpeg2 into a VCD for this player is somewhat of a pointless exercise unless you trying to take advantage of a mpeg2 extra features such as subtitles.
<font size=-1>[ This Message was edited by: Kdiddy on 2002-01-17 11:27:33 ]</font>
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 21:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 21:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15
