Hi. I have a 5.1 ac3 file that I ripped. My question is how do I open it so it is in it's individual streams such as center channel channel, left channel, right channel, etc. If there is anyway to do this with Sound Forge or Vegas, I have those programs. Thanks.![]()
Results 1 to 13 of 13
Hello
you can open a 5.1 ac3 file in Nuendo 2 It has this fascillity and you can edit individual channels also but you must have the dolby digital plug-in which one has to buy separately and Nuendo price is the big hole in the pocket
I also use Soft Encode for this but I've never figured out how to do it easily. What I mean is I have to load the 5.1 AC-3 then I can save 1 of the 6 channels. After that I have to load the 5.1 AC-3 again and pick another of the 6 channels to save. So yeah I have to do that 6 times LOLOriginally Posted by Pinstripes23
However it seems to work well and in the end you have 6 mono PCM WAV files. After editing them you can then use Soft Encode again to put it all back together into a new 5.1 AC-3 file.
@Pinstripes23
Is there an easier way to do it than the way I am doing it with Soft Encode?
I save it out as .wav file. Then when I use audition it opens it up as 6 different channels. I dunno if other audio editors can do it like this though, maybe soundforge or audacity?Originally Posted by FulciLives
I never tried with Audacity but I remember this not working with SoundForge nor Goldwave.Originally Posted by Pinstripes23
Not something I have to do often but next time I'll give it a try with Audacity.
What I do is load the 5.1 AC-3 then eliminate 5 of the 6 channels then save that 1 remaining channel (giving me a mono wav file). If it is the center channel I'll call it "movie_c.wav" or for the front right speaker I'll call it "movie_fr.wav" etc.
But to do it that way I have to load the original file 6 times ... each time eliminating all but the channel I want. In the end I have 6 different mono wav files.
I do understand what you are saying but like I said ... when I tried it that way ... I don't recall SoundForge opening it up correctly.
Yeah that sounds that can be a pain to load it 6 times. I tried duplicating the output with besweet but IIRC there is a limitation in the azid section with the dialog normalization reduction that doesn't look or sound correct, when comparing it to soft encode's.Originally Posted by FulciLives
Fulci I just tried something with soft encode, that can probably make the process go faster for you.Originally Posted by FulciLives
Open the original ac3, save it out as pcm .wav. Then open up the .wav file in soft encode, and it will create a .sfk file that will make loading the .wav automatically each time afterwards. That way soft encode doesn't spend time decoding the original ac3 every time you load it again. -
Sweet!Originally Posted by Pinstripes23
That was the BIG problem ... every time I load the 5.1 AC-3 into Soft Encode it would do that decoding process and that is what REALLY makes the process take forever.
Thanks for that!
use BeLight,is free very very easy to use.you can do others convertions between formats too.
http://forum.doom9.org/showthread.php?t=85566&highlight=belight
Blu-ray individual a/v/sub streams size tool
By Ennio in forum Blu-ray RippingReplies: 3Last Post: 4th Oct 2011, 01:30 -
Split iMovie09 DV-Streams
By cecco in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 5th Sep 2011, 18:50 -
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 14:34 -
split .264 and .m4a streams
By codemaster in forum EditingReplies: 2Last Post: 3rd Mar 2011, 16:42 -
Split Long MP3 file into Individual Songs
By wulf109 in forum Newbie / General discussionsReplies: 4Last Post: 15th Jul 2010, 22:33
). I looked up Soft Encode, and those price tags were outrageous
