I did notice when I got my new Sony recorder there was no record pause. If you are dubbing from a vhs tape you must hit stop, then wait, and create new title.
Now I went into circuit city and sales guy said this is normal for most units, only that Sony may take longer than most to write to disk.-- so I let it go.
But today, was just looking at reviews of unit, and a lot of people complaining about lack of this feature. Wondering, is this a crazy ommision from Sony or par for the course?
Kevs,
cnet.com has a great deal of in depth reviews that you can compare to the reviews here.
Among, the major problems they outlined with the recent Sony's was this exact drawback.
The Panny i have (DMR-ES25, chosen over the Sony GX330) will pause. When you pause and then resume recording: it simply makes a new chapter after the pause point (specifically on +R/-R/non-RW disks, it creates a new chapter... on RW and Ram disks you can edit and create chapters). Of course you can compile any disks and edit them on the comp.
It seems to be a common feature with Sony's, and their quality (while being superior to VHS) isn't as good as other brands.
Frankly, as many have outlined Panny's are not always the best of quality, but when you compare VHS to pretty much any DVD recorder, you will find that they all surpass the quality of VHS.
It's a matter of function, ease of use and what exactly you are looking for in your recorder of choice. If you are still able to exchange, i would look for a Panny (easy to use, good quality), Pioneer (great quality, fairly easy to use) or the whole JVC vs Toshiba vs Polaroid debate.
I hope that rambling helps a bit,
ACLU guy -
Originally Posted by kevs
ACLU
thanks, panny is panasonic, right? I tested one, and the layout was not nearly as easy and fluid as Sony. could you please provide the cnet link on that review for me? thanks
when you hit pause, how long is the wait to record again? you have to wait for writing, right?
still what you are saying is that the Sony which does not pause, it's an asinine ommission, right?
Like building a car without air, or electric windows, it's nuts or is some hidden logic? How could they do that then. This isn't Bob's DVD players, it's Sony,-- unless that have a good reason, we can't figure out? -
The Panasonic's are extremely user-friendly, aside from the medium you are recording on and the finalizing after record, it's the same as a VCR (but a somewhat-new layout to learn)...
The thing is, after you record, and use the disk management menu (under functions) you will see three options, among finalizing there is "where disk starts playing." You can set it to start playing with those chapter menus or with the first title. If you chose first title, (ie: autoplay) you will never even see the new chapters it makes (making this paragraph really moot and only an elaboration on what it does to menus when you pause and resume). After all, when you finalize a disk it will create chapters to skip to every 4 minutes in the disk... Sorry i digressed and rambled for a moment.
I hope that helps, the wild were playing tonight so it has been beer o'clock for a while. If any of this is incoherent or is in need of elaboration, let me know, i'd be glad to answer more.
ACLU guy
Postscript: here is the link to the sony GX330 review on Cnet, it shows user opinions where several mention the lack of record-pausing...
Sony GX330: http://google-cnet.com.com/Sony_RDR_GX330/4505-9141_7-31789597.html?tag=sub
The unit i use (same as es15 but with HDMI or 45 but without VHS): http://google-cnet.com.com/Panasonic_DMR_ES25S/4505-9141_7-31904063.html?tag=coco
Post-Postscript: Those were the two recorders i had broken my choices down to on the basis of my needs and price concerns. If you want to spend more or get a HDD recorder, the Pioneer 640H-S looks spectacular. Others will point to LG as another top brand, or polaroids / jvc / toshibas.
Sadly, Sony really isn't a top tier recorder (maybe when it comes to blu-ray or HD-DVD they will be first to innovate, but they are not leading the curve in DVD recorders now... Panny was the number one, and still has a huge following at avs forums, but others have surpassed them marginally in quality. (when compared to vhs there is still no comparison)
final thought: make sure you finalize your disks after you record, this is a pivitol point to be made, which has been made again and again here. Best of luck my friend!
LATE EDIT: I believe i may have been wrong when i stated that pausing creates a new title/chapter. It may be the stop button that creates a new chapter/title when you start recording again. Sorry for the confusion, i have yet to really screw around with RW/Ram disks while pausing or stopping.
Rec.709 to RGB24 to Rec.601
By Anonymous344 in forum Newbie / General discussionsReplies: 8Last Post: 2nd May 2011, 18:40 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Avysinth for ,rec file
By ahidayat in forum Newbie / General discussionsReplies: 4Last Post: 2nd Mar 2009, 04:51
