Hi, I have a few questions here.. first of all, how do I get ffdshow off my computer.. in intentionaly uninstalled it a few months ago, but now it is back.. I have installed a number of different encoders and authoring programs, trying to find which I liked best and it probably came from one of those, but I cant find it.. or should I leave it .. most of the programs seem to use it for previews..
another question.. is it better to merge 2 avi files together before encoding to dvd.. or does it make any difference if Im using Cucusoft avi to dvd converter to merge the files into dvd.. Also is cucusoft anygood? I didnt really want to use it, but its the only one I have that merges avi files - could anyone recommend something else. I am a noob to this, but dont like noob software, as I never learn what Im doing if its all done for me without much control.. also I want quality encoding..
I had other questions, but now I forgot.. ohh well.. any input would be appreciated.. thanks..
1. Search for ffdshow with windows explorer. then run the unist000.exe in the ffdshow folder.
2. Don't merge, it often cause sync problems and other problems. use instead convertxtodvd and add both avis and convert to dvd. Or if you want control read a guide like https://www.videohelp.com/guides.php?guideid=710&howtoselect=4;10#710 .
A couple of questions for the experts?
By Rumdaddy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2011, 12:54 -
a couple of 1080i questions
By deadrats in forum Video ConversionReplies: 14Last Post: 29th Aug 2009, 20:11 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
a couple of questions ..
By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 14:21 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 11:22
