Sorry not sure where to put this.
Have just bought a Toshiba DVD Recorder in the states (Toshiba D-R5SU/D-R5SC)-although the recorder itself only says D-R5.
I need someone to please tell me how to reset the region code to "O" - I have looked on the search and cant find anything.
Hoping that someone can help me......thanks
	lizzie
	This page on "DVD Hacks" on the left side menu "Lists" in this forum shows none for your model.
 https://www.videohelp.com/dvdhacks.php?dvdplayer=Toshiba&hits=50&Search=Search
 It's better to research first and then buy.
	I'll move you to our DVD Recorder Forum where you may get more answers.
 EDIT: After reading your post and title a second time, I'm wondering if you are asking about the DVD media? Burned media doesn't usually have region coding, unless it was put in for some reason. Region settings are for playback and to discourage copying of commercial media. If you are asking about playback, then someone here may have some ideas.
 And welcome to our forums.
	My problem is that I bought the dvd recorder in the states, as a friend told me of the hackers site, and that they have instructions to change region codes for every make - obviously this dvd is set to region 1 for american dvd playing, and I have come from Europe, and all my dvds are region2 code. Hopefully someone can help me to set the code so that I can play back any region.Originally Posted by redwudzlizzie
	Buy a cheap player that you can change the region on. Recorders seldom make good players anyway....
	Did you ever find a code to unlock that machine. I just got one and have had no luck searching for a code to reset the region. Thanks.
  XviD4PSP Brightness/Contrast setting to reduce PSP "Ghosting"?By stephens in forum Video ConversionReplies: 0Last Post: 13th Sep 2009, 12:42
  Samsung BD-UP5000 Region "A", Region "1"By lastbutthree in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Sep 2009, 14:24
  Video Setting For Motorola A1200 "Ming" and Rokr E6 EntertainmentBy dj4monie in forum Portable VideoReplies: 2Last Post: 6th Jul 2008, 03:20
  Black and white picture on NTSC television from "region free" DVDBy psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
