Is there a way to make windows movie maker create the VTS files for burning a DVD? I'm trying to burn my movie with Nero and not movie maker
No. Export to DV-AVI and then use an all-in-one dvd converter/authoring tool like Nerovision, Ulead dvd moviefactory, ConvertXtoDVD....not the best quality but they are easy to use.
https://forum.videohelp.com/viewtopic.php?p=1642488#1642488
You'll get an idea from this after the output from windows movie maker as dv avi , but export no more than 3 minute's worth at a time .
You might want to grab a dv converter incase vdub spit's on the audio being wrong type .
Then use the append feature to join them in the correct order .
Set audio to full processing , no compression , conversion to 48khz , 16bit , stereo ... save as wav .
The rest is explained in the other post ... but you may need a avisynth script to link the avi's together in order for quenc to do it in one pass ... something like alignsplice ... I forget ... that's why I have multiple backups ... incase my mind fry's itself .
Search the forum for avisynth script should turn up the thing ... it refer's to how to join them in the correct order ... or baldrick might know what I am talking about ... it's been one hell of a night .
Windows Movie Maker
By moonshadow in forum Capturing and VCRReplies: 1Last Post: 4th Nov 2009, 08:59 -
windows movie maker
By c_paquette in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 14:51 -
Question Windows Movie Maker
By crowheart in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2008, 13:14 -
windows movie maker
By nebrovelant in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2007, 16:46 -
fraps, windows movie maker, x264 question
By combatsimulation in forum Video ConversionReplies: 0Last Post: 20th Jul 2007, 14:21
