  1. I useTMPGEnc DVD to change the DVB-T recording movies to DVD. I test the folder with DVD player and it seems to works fine. However, when I use SimpleDivx to encode that DVD folder to avi file, sometimes it works and quite many time I end up with soimething WMP can not play. Using AVIcodec to inspect so it saya that the strange format FDM or something is not supported.
    Yersterday I use simple Divx to change DVD folder ripped from DVD and it works flawlessly. Can someone helps me.
    Try AutoGK and see if it works better with the dvd from tda. Or convert directly from the DVBT files to DivX with AutoGK.
