So, if your optical drive stops recognizing discs properly, and you might be able to hear a slight scraping sound as the unit tries to read it, check to see if the ribbon is clear of the disc's path.
Hope this is useful.
Interesting diagnosis Dak, that sounds exactly like what my hacked AKAI DVD recorder is doing. You can actually see the scratch on the newly made coaster. I thought it was headed for DVD recorder heaven, but maybe not.
I do have a question. I just bought the polaroid and encountered the usual remote issues, so I'll break out the soldering iron. It's been a while since I used that thing. Is there a higher power LED by any chance, recorder placement is such that I need to go slightly around the top of the set?
Otherwise, this is an impressive machine that played Region 2 PAL discs right out of the box. No hacks needed. It replaced a Philips 642/75 that worked nicely, but it developed burner issues. It had 2(!) sets of component in jacks. I couldn't find anything like that out there that had that. The Polaroid was closest. Now I use the Philips as a "switcher" feeding the Polaroid's component in jacks. Clunky, but I have a choice of component inputs. Sad that component inputs are going the way of the buggy whip.
A HD switchout is next.
Great forum, thanks for all the info, everyone.
Results 91 to 94 of 94
Finally broke down this week & got Polaroid from Wally World for 149.99 open box. I need to stop my behavior, I brought a RCA now a Polaroid. This is the worst kind of Drug (DVD recorder). I won't sleep tonight because I got a new toy to play with. This has been a sleepless week......
Can you explain a bit more on this? Re-Author them? Do you mean burn them to a DVD, then put it in your computer and rip it? Ive not seen any type of software that will let you fit on a DVD as much as you can when rec to a DVD from stuff rec on the Burners hard drive.Originally Posted by Barnabas
Thanks.Jess -
How do you get the little timer/polaroid icon in the bottom rt corner of screen to disappear?
No hovering effect in the menu button after customizing
By yozloy in forum Authoring (DVD)Replies: 7Last Post: 25th Dec 2011, 12:42 -
Customizing PotPlayer
By positcert in forum Software PlayingReplies: 0Last Post: 13th Sep 2011, 19:57 -
Help customizing a computer for video editing.
By vid83 in forum ComputerReplies: 3Last Post: 8th Feb 2009, 04:08 -
customizing a laptop online
By patrick_jimmy in forum ComputerReplies: 4Last Post: 2nd Oct 2007, 13:25 -
Polaroid DRM2001G Timer Problems
By Fused0ne in forum DVD & Blu-ray RecordersReplies: 0Last Post: 17th May 2007, 11:12
