I have the Belking F5U503 and I have the drivers, in the device manager it's installed properlly and said it's working (there's no ? next to it) but I downloaded Ulead VideoStudio, Windows Movie Maker and WinDV and DVIO all won't work. None of them are showing that my camera is connected. I have it hooked up through the i.link to the FireWire Card. The Cam is a Panasonic MiniDV model PV-DV701D. Anyone know what might be the prob? Thanks
Broom
Disconnect the camera .
Turn pc off .
Power camera from the supplied power adapter .
Turn camera on , and to the correct mode .
Connect ieee cable to pc card .
Turn pc on ... and it should pick the device up ... it's like having a tunnel ... but the lights arent on between the two side's yet .
And this is the correct order to connect the device to the pc ... do it the other way has been known to cause problem's for camera and / or pc ... the manufacturer's have noted this on site .
You may also need to check you have the ieee patch for your current os , and I think there was another , that safe removal device tool as well you need ... do the update NOW ... they'll be gone sooner than later .
Finally , what directx version are you currently running ?
What about the camera's driver's ?
Check they are compatible with your current os ... if not ... that's a problem . -
I'll try that. I just installed the latest drivers for the camera from the website and I downloaded the drivers for the firewire card today from their site so it should all be the most updated possible.
This didn't work, any other ideas? I've emailed Panasonic twice now with no response since I posted this
Basic AVCHD video Editing Tools
By glenpinn in forum EditingReplies: 27Last Post: 18th Jun 2009, 10:14 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 11:53 -
[SOLVED] DLT8000 installed - 15 devices listed in device manager? ?
By sdsumike619 in forum Authoring (DVD)Replies: 6Last Post: 19th Jun 2008, 20:05 -
Recommendations for Video Editing Tools
By Bald Eagle in forum EditingReplies: 12Last Post: 24th Jan 2008, 02:28 -
External drive not showing in Device Manager
By alegator in forum ComputerReplies: 15Last Post: 10th Dec 2007, 13:38
