Hi Gang
I am not exacetly new to this I have been using my Tivo, to capture programs/movies and get them onto my computer for some time now. But recently I have been having problems with the movies, they do not come out very good or not at all. It goes through the process all right it appears, but the end result is, incomplete or with freeze ups, etc. I am using temp pro to access my Tivo and Tytool 9r1 to access the info. I am thinking of dumping them and starting fresh with the latest and greatest. I have been using them for a couple of years now.
So I am sure there are better ways out there now. So this is where you come in, I would appreciate any advice you all can give me as to what to use.
Thanks........Gunny
If you have windows try directshowdump. It outputs a clean mpg to use in any program. Though you will have to convert it to dvd mode to burn a dvd of course.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
