Newbe here : i have recorded my shows onto my PC with my TV card, (cheap one), and they are recored as MPEG2, 6000fps, YUV2, i think. Q. Can i author these mpeg2 files to give them chapters, or put a menu on at the beginning and then transfer them to DVD, i'm confused about diff's between avi's, nuv's, mpeg's, divx etc. Note: for future reference i can record in AVI, mpeg1/2/4, as the rec software gives me these options... I have copied/burned the mpeg2 files to a DVD & they played ok on a standalone DVD player (to a TV), are they a diff format on the DVD ?
Ooops, that (DVD) link wont work for me !!! but this forum one does !!! doh!
Can u copy/tell me what that link says, if the text isnt too long.....pls & tnx. -
DVD stands for Digital Versatile/Video Disc, DVDR stands for DVD Recordable and DVDRW for DVD ReWriteable. If you're familiar with regular audio/music CDs or regular DVD-Video discs, then you will know what a recordable DVD looks like. A recordable DVD stores up to 2 hours of very good quality DVD-Video, including several audio tracks in formats like stereo, Dolby Digital or DTS and also advanced menu systems, subtitles and still pictures that can be played by many standalone DVD Players and most computer DVD-ROMs. If you choose to lower the video quality it is possible to store several hours video on a recordable DVD using low bitrates and low resolution with video quality more like VHS, SVHS, SVCD, CVD or VCD. It is also possible to have up to 4.37* GB ordinary data or mix DVD-Video and data on a recordable DVD that can be played by most computer DVD-ROMs.
There are three competing DVD Recording standards, DVD-R/DVD-RW and DVD+R/DVD+RW have pretty similiar features and are compatible with many standalone DVD Players and most DVD-ROMs while DVD-RAM has less DVD Player and DVD-ROM compatibility but better recording features.
DVD-R and DVD-RW
DVD-R was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 80% of all DVD Players and most DVD-ROMs.
DVD-R and DVD-RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R is a non-rewritable format and it is compatible with about 89% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R and DVD+RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
DVD+R DL
DVD+R DL or called DVD+R9 is a Dual Layer writeable DVD+R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
DVD-R DL
DVD-R DL or called DVD-R9 is a Dual Layer writeable DVD-R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
DVD-RAM
DVD-RAM has the best recording features but it is not compatible with most DVD-ROM drives and DVD-Video players. Think more of it as a removable hard disk. DVD-RAM is usually used in some DVD Recorders.
This format is supported by DVDForum.
Read our DVD Writers and Recorders list and read also our DVD Players Compatibility list to see what types your standalone DVD Player supports. You find more detailed comparisons between the formats in the more info section here.
DVD Sizes
The DVD sizes can be a bit confusing. There are basicly 4 different DVD Sizes,
DVD-5, holds around 4 700 000 000 bytes and that is 4.37 computer GB where 1 kbyte is 1024 bytes* . DVD+R/DVD+RW and DVD-R/DVD-RW supports this format. Also called Single Sided Single Layered. This is the most common DVD Media, often called 4.7 GB Media.
DVD-10, holds around 9 400 000 000 bytes and that is 8.75 computer GB. DVD+R/DVD+RW and DVD-R/DVD-RW supports this format. Also called Double Sided Single Layered.
DVD-9, holds around 8 540 000 000 bytes and that is 7.95 computer GB. DVD+R supports this format. Also called Single Sided Dual Layered. This media is called DVD-R9, DVD-R DL, DVD+R9, DVD+R DL or 8.5 GB Media.
DVD-18, holds around 17 080 000 000 bytes and that is 15.9 computer GB. DVD+R supports this format. Also called Double Sided Dual Layered.
* In the computer world is 1 KB data = 1024 bytes so 4 700 000 000 bytes / 1024 = 4 589 843KB / 1024 = 4482MB / 1024 = 4.37GB. See section 3.3 in the DVDDemystified FAQ here.
DVD+R/DVD+RW/DVD+R DL and DVD-R/DVD-RW exact sizes
DVD-R/DVD-RW = 4 706 074 624 bytes ( 4488 MB )
DVD+R/DVD+RW = 4 700 372 992 bytes ( 4482 MB )
DVD+R DL = 8 547 993 600 bytes ( 8152 MB )
DVD Write and read speeds
Single Layer(4.7GB) write speeds
1x (CLV) = about 58 minutes
2x (CLV) = about 29 minutes
2.4x (CLV) = about 24 minutes
4x (CLV) = about 14.5 minutes
6x (CLV/ZCLV) = about 10-12 minutes
8x (PCAV/ZCLV) = about 8-10 minutes
12x (PCAV/ZCLV) = about 6.5-7.5 minutes
16x (CAV/ZCLV) = about 6-7 minutes
Dual/Double Layer(8.5GB) write speeds
1x CLV = about 105 minutes
2.4x CLV = about 44 minutes
4x CLV = about 27 minutes
Single Layer (4.7GB) read speeds
1x read speed is 1.321MB/s = ~56 minutes
6x CAV (avg. ~4x) read speed is max 7.93MB/s = ~14 minutes
8x CAV (avg. ~6x) read speed is max 10.57MB/s = ~10 minutes
12x CAV (avg. ~8x) read speed is max 15.85MB/s = ~7 minutes
16x CAV (avg. ~12x) read speed is max 21.13MB/s = ~5 minutes
* write speed time and read speed time is not the same because writing requires some extra steps and also does the faster writing above 6x usually use lower write speeds for some parts of the dvd. 4x DVD speed = 36x CD speed. See section 4.2 in the DVDDemystified FAQ here.
Other non-standard special DVD formats:
DVD-VCD
is basicly a VCD authored on a DVD. DVD supports the VCD resolution but the audio has to be resampled to 48 khz. If the audio is resampled to 48 khz it is standard DVD-Video. Read more here how to make a such.
DVD-SVCD
is basicly a SVCD authored on a DVD. DVD do not supports the SVCD resolution but it may anyway work and the audio has to be resampled to 48 khz like the DVD-VCD. Read more here how to make a such and download a DVD Sample including a DVD-SVCD here.
DVD-MP3
is MP3s burned on a DVD but very few MP3 capable standalone DVD Players supports it because most Players verify DVD as DVD-Video only. Check our DVD Players list for compatibility.
DVD-ISO
is MPEG ,MPG, VOB files burned on a DVD without any DVD Authoring(making the vob,ifo files) but very few standalone DVD Players supports it because most Players verify DVD as DVD-Video only. Check our DVD Players list for compatibility.
What is miniDVD / cDVD then?
Read here on the miniDVD/cDVD page.
DVD Samples, DVD-SVCD Samples
DVD Trailers, Dolby Digital, DTS, THX Trailers and some other DVD VOB Trailers
To play the DVD Trailers on your computer use WinDVD and just open the VOB file.
If you would like to burn the VOB Trailers on a DVD you can use Ifoedit to author trailers on a DVD or demultiplex the VOB and then author with for example Spruceup or any author tool that support Dolby Digital(AC3) or DTS.
DVD-SVCD Samples, NTSC and PAL DVD-SVCD samples.
Technical Info for DVD-Video
PAL
Video:
Up to 9.8 Mbps* (9800 kbps*) MPEG2 video
Up to 1.856 Mbps (1856 kbps) MPEG1 video
720 x 576 pixels MPEG2 (Called Full-D1)
704 x 576 pixels MPEG2
352 x 576 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 288 pixels MPEG2
352 x 288 pixels MPEG1 (Same as the VCD Standard)
25 fps*
16:9 Anamorphic (only supported by 720x576)
Audio:
48000 Hz
32 - 1536 kbps
Up to 8 audio tracks containing Dolby Digital, DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have MPEG-1, DD or PCM Audio.
Extras:
Motion menus, still pictures, up to 32 selectable subtitles, seamless branching for multiple storylines, 9 camera angles. And also additional DVD-ROM / data files that only can be read by computer DVD drives.
Total:
Total bitrate including video, audio and subs can be max 10.08 Mbps (10080 kbps)
* Mbps = million bits per second
* kbps = thousand bits per second
* fps = frames per second
For more technical DVD-Video details read the DVDDemystified DVD FAQ section 3.4 or the mpeg.org DVD Technical Notes.
NTSC (NTSC Film)
Video:
720 x 480 pixels MPEG2 (Called Full-D1)
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
29,97 fps*
23,976 fps with 3:2 pulldown = 29,97 playback fps (NTSC Film, this is only supported by MPEG2 video)
16:9 Anamorphic (only supported by 720x480)
Audio:
48000 Hz
32 - 1536 kbps
Up to 8 audio tracks containing DD (Dolby Digital/AC3), DTS, PCM(uncompressed audio), MPEG-1 Layer2. One audio track must have DD or PCM Audio.
Extras:
Total:
For more technical DVD-Video details read the DVDDemystified DVD FAQ section 3.4 or the mpeg.org DVD Technical Notes.He's a liar and a murderer, and I say that with all due respect.
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 21:17 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 02:12 -
Can you author and play BLU RAY using SD MPEG2's?
By faramith in forum DVD RippingReplies: 1Last Post: 4th Jul 2007, 02:11 -
What author tool besides GUI For DVDAuthor for mpeg2 files w/o Nav Packs?
By palouse in forum Authoring (DVD)Replies: 7Last Post: 27th Jun 2007, 06:44
