i burned a the mpeg to a cdr , it is there but no dvd roms or players recognize it . i can open windows media player and it will play in there fine , but still the dvd wont just play it? i dont ave this problem when i convert avi ro mpeg , only when i rip dvd , i used smartripper , dvd2avi , and tmpge . any info would be good help and appreciated .
did you burn the .mpg file as data cd? if you did, you need to burn it using nero's (S)VCD templates (mode 2/xa). only that way will most standalone players recognize it.
no i did not burn as data . i burned as vcd . my dvd rom will play the vcd ripped from a DVD . but my stand alone wont . my stand alone will however read a avi converted to mpg . i dont understand that .
go here:
http://www.vcdhelp.com/dvdplayers.php
and find info about the standalone dvd player you have. -
thank you for your help , but the problem was my burner took a dump on me , i replaced and now its fine
thanks again for your input .
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Dl burning problems
By calanda in forum DVD RippingReplies: 13Last Post: 13th Apr 2010, 23:25 -
TYG02 burning problems.
By videobread in forum MediaReplies: 2Last Post: 11th Oct 2009, 12:51 -
DVD burning problems
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 00:11 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 15:36
