Is it possible to do? What kind of software could i use?
THANKSSS
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Depends on input audio format (mp3 is no good) and how the recording is done.
Take a look at AnalogX vocal remover to get an idea of what can be done. Don't expect miracles.
/Mats -
Originally Posted by sagingrepublic
Typically, the vocal track is dead-centre in the stereo mix. If you invert one of the stereo channels and then create a mono signal (i.e., create left minus right or right minus left), often the vocal will disappear. This is how a lot of karaoke machines work.
(It's also why you have to be careful when creating stereo soundtracks that may be heard on mono equipment - if the left and right are out of phase, often the dialog (vocal) disappears).
So, anyway, if you have stereo source material, you need to:
1. Invert one of the channels
2. Add the two channels together to create an out-of-phase mono signal
If the vocal has any chorus effects (for example), these may still be heard but most of the vocal will disappear.John Miller -
Also, if it's not a big-label artist, contact the artist. You'd be surprised what you can get just by... ...asking.
software to mute the singer's lyrics but keep the music?
By jbitakis in forum AudioReplies: 13Last Post: 17th Jun 2012, 10:59 -
How to mute sound for abusive words in a movie
By smarty3010 in forum AudioReplies: 14Last Post: 1st Nov 2011, 11:52 -
Trying to separate music from the rest of the audio in a video.
By walkerrhodes in forum AudioReplies: 8Last Post: 21st May 2011, 03:18 -
How to rip separate songs from a music dvd...
By lordhutt in forum DVD RippingReplies: 4Last Post: 31st Dec 2008, 13:50 -
How Can I Separate DVD Music & Commentary's Voice?
By Aaron1927 in forum AudioReplies: 5Last Post: 10th Aug 2007, 17:28
