Hi
This will be a big challenge for some of u's here
I get these errors while i try to conver mpg1 files to dvd using tda 1.5 , when i try it on tda 1.6 it says divided by 0 or divided 0.
Results 1 to 9 of 9
Originally Posted by nirbhayn
of course it doesn't
did you notice my other part of previous reply...? -
TDA will convert the audio from 44.1Khz to 48Khz and author a MPEG-1 to DVD. But make sure the video is VCD compliant and I believe the audio needs to be VCD compliant also: 44100 Hz 224 kbit/sec MPEG-1 Layer2. I'm not sure that has anything to do with your errors, though.
You spoiled my answerOriginally Posted by redwudz
I wanted OP to use his briains on his own, specially that (me thinks) the answer is already in his first screencap... sfmpgdec.dll is Pegasys' own mpeg decoder, included in TDA, TMPGEnc and probably all their software - so if it errors out in TDA its most likely because his MPEG-1 files are not VCD compliant as you said... -
You have to be quick around here sometimes.
I wondered why you didn't mention non-compliance.
Perhaps it is too dumb and it only complains when its down on its knees already?Originally Posted by nirbhayn
Check the specs of your source file(s) and post it back, please?
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 12:29 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 16:32 -
TDA errors
By siluet in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2009, 08:08 -
wma to mp3 errors; losing file size on conversion
By gidget00 in forum ffmpegX general discussionReplies: 1Last Post: 22nd Aug 2008, 19:48 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04
