I am using TMPGEnc Plus to encode my movies which are in .avi format. but some movies i open up it wont recognize the audio in the movie, so there wont be any sound when its done encoding. So I tried using Goldwave to extract the audio out of the .avi and save it in .wav format, so then I used my TMPGEnc DVD Author to turn the mpeg i created into .VOB files so i can burn them onto a dvd+r. So I open up the mpeg and it uses the .wav I created from goldwave but after it creates the .VOB files the audio is just a tiny bit out of sync with the movie?? how do I fix this? what is the right process from the beginning? what am I doing wrong? can anyone help me please!! thank you
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Grab gspot , it will confirm the internals of the avi .
Try opening it in vdub , and set audio to full processing , the audio compression to none , followed by setting the conversion to 48khz / 16bit / stereo ... save as wav .
You can sync the audio using syncview , audacity , goldwave ... and there's an odd avisynth script or two the show's the same process to work out the time difference and to extract the audio .
In the case of mpeg , use virtualmod instead ... if it's only a faction out , you could use audacity to stretch it out .
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 15:07 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 18:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 21:31 -
Avisynth/TMPGEnc Xpress Audio Sync Issue
By Borflex in forum Video ConversionReplies: 4Last Post: 2nd Jun 2007, 15:10
