I have a 713KB avi file which i started to carry out the dvd conversion.
started at 11.50 and by 4pm it was finished ????? normally it would take 8 hours or so.
I did notice that a bubble popped up saying something about low virtual memory,would this be the reason why i only have a dvd duration of 21 minutes.
Not sure why this message popped up as i have 1 gig memory and only s2d was running and a spare 100 gig on the hard drive.
Please advise.
Results 1 to 9 of 9
As always - please post your log file.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.1
Version: 2.1.2474.30185
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.86 MB
Executable size in bytes: 3006547
Executable CreationTime: 10/10/2006 16:57:38
Executable LastWriteTime: 14/10/2006 16:18:53
Executable LastAccessTime: 14/01/2007 11:50:29
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 630 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name:
Computer Model:
System Type: X86-based PC
Computer Name: IAN
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: IAN\Iainhome
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Duron(tm) Processor
Description: x86 Family 6 Model 3 Stepping 1
CPU Speed: 945MHz
CPU FSB: 66MHz
L2 Cache Size: 64 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: Xpert 99/Xpert 2000
Processor: Rage128 VR (AGP)
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 8.00 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 11.2 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 72.7 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="14/01/2007 11:51:26" Filename="NONE"><AssetSet><Asset ID="ea29d8a5-6cc4-4bed-b885-b8769f4b8053" Path="D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]" Filename="nedivx-marine.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="nedivx-marine.avi" AssetID="ea29d8a5-6cc4-4bed-b885-b8769f4b8053" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\WINDOWS\Web\Wallpaper\SEAS HORE.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="D:\SVCD2DVD SOURCE" InitialDVDFolder="D:\SVCD2DVD SOURCE\SVCD2MPG TS FOLDER" InitialProjectFolder="D:\SVCD2DVD SOURCE\SVCD2MPG PROJECTS" InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="C:\WINDOWS\Web\Wallpaper\S EASHORE.jpg" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="True" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" DVDDrive="TOSHIBA DVD-ROM SD-R5112" NeroWriteSpeed="Max" Eject="False" HighDVDCompat="False" VerifyDVD="False" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 696 MB
file=D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine.avi
FormatName=avi
Num_Frames=131426
DurationInSecs=5480
Duration=01:31:20.8
VideoCodec=mpeg4
Width=608
Height=336
Standard=NTSC (Film)
BitRate=1066
AudioStreamCount=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=32
Audio1Channels=2
AVI2MPG: 6400kbs Full-D1
11:51:26: Looking for AVI PAR...
Pass 1/1: Processing nedivx-marine.avi
11:51:29: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
11:51:29: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
11:51:29: libavutil version: 49.0.0
11:51:29: libavcodec version: 51.4.0
11:51:29: libavformat version: 50.2.1
11:51:29: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
11:51:29: Input #0, avi, from 'D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine.avi':
11:51:29: Duration: 01:31:20.8, start: 0.000000, bitrate: 1066 kb/s
11:51:29: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 608x336
11:51:29: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 32 kb/s
11:51:29: Output #0, dvd, to 'D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2D.mpg':
11:51:29: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 6400 kb/s
11:51:29: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
11:51:29: Stream mapping:
11:51:29: Stream #0.0 -> #0.0
11:51:29: Stream #0.1 -> #0.1
15:31:09: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing nedivx-marine_S2D.mpg
15:31:15: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
15:31:15: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
15:31:15: libavutil version: 49.0.0
15:31:15: libavcodec version: 51.4.0
15:31:15: libavformat version: 50.2.1
15:31:15: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
15:31:15: Input #0, mpeg, from 'D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film).mpg':
15:31:15: Duration: 00:21:12.8, start: 0.500000, bitrate: 6453 kb/s
15:31:15: Stream #0.0[0x1e0], 23.98 fps(r): Video: mpeg2video, yuv420p, 720x480, 9000 kb/s
15:31:15: Stream #0.1[0x1c0]: Audio: mp2, 48000 Hz, stereo, 224 kb/s
15:31:15: Output #0, rawvideo, to 'D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film).mpv':
15:31:15: Stream #0.0, 23.98 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s
15:31:15: Output #1, mp2, to 'D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film).mp2':
15:31:15: Stream #1.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
15:31:15: Stream mapping:
15:31:15: Stream #0.0 -> #0.0
15:31:15: Stream #0.1 -> #1.0
15:33:07: NTSC(Film)->NTSC: Applying Pulldown nedivx-marine_S2DNTSC(Film).mpv
15:33:07: video:950792kB audio:34804kB global headers:0kB muxing overhead -3.531220%
15:33:08: SVCD2DVD: Convert2NTSC: Converting....
15:41:36: NTSC(Film)->NTSC: Muxing nedivx-marine_S2D.mpg
15:44:29: Done: Processing assets for DVD creation
Authoring DVD Folders
15:44:29: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
15:44:29: INFO: [???] File D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
15:44:29: INFO: [???] File D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film).mp2 looks like an MPEG Audio stream.
15:44:29: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
15:44:29: INFO: [???] Found 1 audio streams and 1 video streams
15:44:29: INFO: [???] Selecting dvdauthor DVD output profile
15:44:29: INFO: [???] Multiplexing video program stream!
15:44:29: INFO: [???] Scanning for header info: Video stream e0 (D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film)_pd.mpv)
15:44:29: INFO: [???] VIDEO STREAM: e0
15:44:29: INFO: [???] Frame width : 720
15:44:29: INFO: [???] Frame height : 480
15:44:29: INFO: [???] Aspect ratio : 16:9 display
15:44:29: INFO: [???] Picture rate : 29.970 frames/sec
15:44:29: INFO: [???] Bit rate : 9000000 bits/sec
15:44:29: INFO: [???] Vbv buffer size : 229376 bytes
15:44:29: INFO: [???] CSPF : 0
15:44:29: INFO: [???] Scanning for header info: Audio stream c0 (D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2DNTSC(Film).mp2)
15:44:29: INFO: [???] MPEG AUDIO STREAM: c0
15:44:29: INFO: [???] Audio version : 1.0
15:44:29: INFO: [???] Layer : 2
15:44:29: INFO: [???] CRC checksums : no
15:44:29: INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
15:44:29: INFO: [???] Frequency : 48000 Hz
15:44:29: INFO: [???] Mode : 0 stereo
15:44:29: INFO: [???] Mode extension : 0
15:44:29: INFO: [???] Copyright bit : 0 no copyright
15:44:29: INFO: [???] Original/Copy : 1 original
15:44:29: INFO: [???] Emphasis : 0 none
15:44:29: INFO: [???] SYSTEMS/PROGRAM stream:
15:44:29: INFO: [???] rough-guess multiplexed stream data rate : 9419800
15:44:29: INFO: [???] target data-rate specified : 10080000
15:44:29: INFO: [???] Setting specified specified data rate: 10080000
15:44:29: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
15:44:29: INFO: [???] New sequence commences...
15:44:29: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
15:44:29: INFO: [???] Audio c0: buf= 0 frame=000000 sector=00000000
15:44:29: INFO: [???] STREAM e0 completed @ frame 30521.
15:44:29: INFO: [???] STREAM c0 completed @ frame 53033.
15:44:29: INFO: [???] Multiplex completion at SCR=114554587.
15:44:29: INFO: [???] Video e0: buf= 231222 frame=030521 sector=00481749
15:44:29: INFO: [???] Audio c0: buf= 4032 frame=053033 sector=00017643
15:44:29: INFO: [???] VIDEO_STATISTICS: e0
15:44:29: INFO: [???] Video Stream length: 973611314 bytes
15:44:29: INFO: [???] Sequence headers: 1905
15:44:29: INFO: [???] Sequence ends : 0
15:44:29: INFO: [???] No. Pictures : 30522
15:44:29: INFO: [???] No. Groups : 1905
15:44:29: INFO: [???] No. I Frames : 1905 avg. size 49635 bytes
15:44:29: INFO: [???] No. P Frames : 8271 avg. size 39137 bytes
15:44:29: INFO: [???] No. B Frames : 20347 avg. size 27291 bytes
15:44:29: INFO: [???] Average bit-rate : 6117600 bits/sec
15:44:29: INFO: [???] Peak bit-rate : 11640000 bits/sec
15:44:29: INFO: [???] BUFFERING min 15 Buf max 211535
15:44:29: INFO: [???] AUDIO_STATISTICS: c0
15:44:29: INFO: [???] Audio stream length 35638848 bytes.
15:44:29: INFO: [???] Syncwords : 53034
15:44:29: INFO: [???] Frames : 53034 padded
15:44:29: INFO: [???] Frames : 0 unpadded
15:44:29: INFO: [???] BUFFERING min 15 Buf max 683
15:44:29: INFO: [???] MUX STATUS: no under-runs detected.
15:44:29: Creating TitleSet # 1
15:44:30: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
15:44:30: -->: DVDFolders creating VTS
15:44:30: -->: VTS 01
15:44:30:
DVD Folders: Processing D:\GRABIT DOWNLOADS\alt.binaries.b4e\2282587_The_Marine_Unra ted_(2006)[2]\nedivx-marine_S2D.mpg...
15:46:13:
15:46:24:
15:46:24: Finalising DVD...
15:46:24: SVCD2DVD: DVDfolders
15:46:24: -->: DVDFolders creating table of contents
15:46:24: scanning D:\SVCD2DVD SOURCE\SVCD2MPG TS FOLDER\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
15:46:24: Finalising DVD...Done
15:46:24: Done: Authoring DVD Folders -
Is it only this file which is causing the issue?
8 hours!! Wow that's a long "usual" duration. What is your PC?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
It normally works no problem.
It takes about 6/7 hours at least but beside that the point i am making is i only had a 21 minute dvd ????
I am now going to give it another go and see what happens.
I will come back with the results. -
Just done it again.
5 hours into the conversion up pops virtual memory message conversion ends and i now have a 979MB film which is about 20 minutes long.
I have the same pc as ever and also cleaning the hard drive etc.
Just going to forget it now,cheers -
To be honest it will most likely be just that file... especially if you have not had the same issue with any other... If you want you could drop me an email so i can give you a location to FTP the file to for me to check...
Aspect ratio and conversion issues with an AVI file.
By destino in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2012, 06:30 -
AVI to AC3 conversion question --Aftern and FFMPEG issues
By eclipse95 in forum AudioReplies: 3Last Post: 9th May 2009, 01:50 -
Conversion and playback issues.
By tooham in forum Video ConversionReplies: 1Last Post: 17th Feb 2009, 10:18 -
By tooham in forum DVD RippingReplies: 1Last Post: 17th Feb 2009, 10:15 -
.MP4 to .AVI Conversion Issues - Loss of Sound, Won't Run to Completion
By gumrunner505 in forum ffmpegX general discussionReplies: 1Last Post: 10th Oct 2007, 19:49
