Any played closes now when i try to watch a AVI file, it opens, but closes right after...
Try re-registering quartz.dll
(search for it here - it's been mentioned in several threads)
If that doesn't do it - it's a codec problem. Use codec sniper or equiv to spot the culprit, remove and reinstall.
Try playing your AVI with VLC. It has its own codecs, and don't rely on DirectShow.
/Mats -
I tryed doing the command regsvr32 quartz.dll and didnt work, also used the codec sniper to check and it says all my codecs are OK...Originally Posted by mats.hogberg
Tried playing with VLC?
Is it one particular AVI, or is it all avi files?
/Mats -
Grab the tool from this site : http://paul.glagla.free.fr/filmerit_en.htm
And check directshow once more ... codec sniper isnt that handy ... read the page on how it works .
I'll ask this one .
Codec pack's ... get rid of them ... install only those you actually need .
Ffdshow ... you got ... get rid of it ... install and use only when required ... it can cause problems .
Vga driver's ... are they up to date ... driver's can go off without being influenced ... it happen's .
May also want to do a registry scan for problem's .
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Media Player Classic can't play TS files
By Mylo in forum Software PlayingReplies: 14Last Post: 8th Mar 2012, 05:26 -
Which Media player will play this Video ?
By goldtree in forum Video ConversionReplies: 7Last Post: 17th Feb 2010, 09:21 -
Can't play H264 with Media Player Classic
By kruuth in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2008, 18:21 -
Cannot play wmv in Windows Media Player
By Frank823 in forum Software PlayingReplies: 2Last Post: 4th Aug 2007, 13:42
