    Jan 2001
    Montreal, Quebec, Canada
    I am trying to encode a DivX to VCD using TMPGENC. I selected the VCD(PAL) Template and only changed the video quality to High. Now when I encode the first 70 mins on the DivX I end up with a 1.9Gb MPG file. What give?
    DivX Specs:
    Audio: MP3 - 15.999 Kbps - 44.1 kHz - Stereo
    Video: DivX 3.11a 640 X 272 @ 25fps (153.966 Kbps/24Bits)
    70.6 minutes 105903 frames
    Regards,
    Spooky
    spooky@videotron.ca
    ICQ @ 21769768
    check if the vcd mpg is black after 70 min...if so you cut that part out....and use the select source range in tmpgenc next time you encode to be sure it dont encodes anything extra.
    Jan 2001
    Any other ideas ?!?!
    Regards,
    Spooky
    spooky@videotron.ca
    ICQ @ 21769768
