All I am trying to do is transfer HD content from my DirecTivo (HR10-250) to my Mac. Is there a product out there that can do this without hacking the Tivo?[/b]
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I have searched the forum and there is nothing which addresses my question.
I'm not sure about mac but there are a few restrictions for transferring tivo without hacking.
First of all I believe only series 2 models enable the tivo-to-go feature. Second of all you need the tivo desktop software. I have the windows version but i"m pretty sure there is a mac version. Third you need either a usb wireless tivo compatible transmitter OR a lan cable to connect your tivo to your computer.
Now I don't know about directivo. They may be slitely different from an official straight tivo only branded box. I have a series 2 official tivo box and can do tivo-to-go transfers. I bought the 60-70 dollar wifi tivo adapter and I set it up to find my wireless network and have been able to transfer the .tivo files without hacking.
EDIT - also I'm not sure that high def tivos have enabled tivo-to-go - I do not know if thats what you mean by hd tivo or not - I belive the new series 3 does not have tivo-to-go enabled at the moment. That is what you need to transfer digital files without hacking.
Also there are many dedicated tivo forums out there, I suggest you do some browsing - maybe type in your model number of your tivo and you'll find related info.Good luck.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The only method for transferring HD video from any kind of DVR to a Mac is via a Firewire link using Apple's Firewire SDK21 VirtualDVHS application. But that only works when the source is not 5c copy protected which essentially means only major Network HD programming can be transferred. I don't know if your DirecTiVo has a Firewire output, but if it doesn't there is no way to export the HD video.
Recently got a TiVO series 4 HD dvr via my cable provider (RCN) and I have a MacBook Pro (purchased earlier this year). I'm trying to use Toast Titanium 10 to access some movies I've dvr'd already with the MacBook but am having difficulties accessing the dvr. I've followed the directions here:
http://www.tivo.com/mytivo/howto/record-once-watch-anywhere/howto_transfer_shows_pc.html
...but I cannot get the dvr to show when I launch TiVo transfer and enter the Media Access Key. Any positive help would be gladly appreciated. If there's more details needed to help come up with answers, please ask and I'll supply as quickly as I can.
Thanks well in advance!
Ben
Capturing VHS to Mac via Panasonic AG-1980 and ATI 650 USB Mac
By Stu187 in forum Capturing and VCRReplies: 3Last Post: 15th Aug 2010, 05:45 -
TIVO and moving to the Mac
By rotuts in forum MacReplies: 2Last Post: 1st Jun 2010, 17:50 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 05:18 -
Tivo files to other formats on a Mac
By whoisquilty in forum MacReplies: 3Last Post: 9th Mar 2010, 17:35 -
Transfer files from Mac to Tivo
By whoisquilty in forum MacReplies: 3Last Post: 8th Jan 2009, 13:56
