Looking at FF instead of cleaner as we are testing a mactel machine.
I want to create an mpeg-1 that is faithfull to the .mov source image; It seems to create a black bar left and right; see my .png image (note the top and bottom "letter box" is as the original.
I searched and found someone explained the same problem as myself some time ago:
https://forum.videohelp.com/viewtopic.php?p=1067486&highlight=black+edge+left+right#1067486
Youre suggestion would be appreciated.
thanks
Mark
Set ffmpegX to a VCD preset, then change some settings, so that it is no longer VCD compliant, but square pixel generic MPEG-1.
In the Summary tab, pick either VCD mpeg2enc or VCD ffmpeg. In the Video tab, set the Video Size width (multiples of 16), then set Autosize to 4:3, which will fill in the height. (E.g. 320x240)
For VCD mpeg2enc, in the Options tab, do not Letterbox and do not use Decode with Quicktime (the latter will change the aspect ratio for playback in QTP). Decode with mplayer or ffmpeg is fine. Set Profile to Generic MPEG-1.
For VCD ffmpeg, in the Options tab, do not Letterbox, but feel free to use the other options. Encoding profile can stay at VCD.
These settings did it right on my test file (DVD source), but only tested with Mac players.
720x576 source video (PAL) is 4:3.
What you've got ending up with looks to be 4:3 also (it has what looks to be a perfect circle). I wouldn't worry.
Note: QT Player OFTEN inadvertantly reports what it estimates as the equivalent SQUAREPIXEL dimensions to what is in fact truly non-squarepixel (like 352x288PAL or 352x240NTSC). It does do a resize to show it with equivalent SquarePixel AR, so all should be well.
I have measured my resulting mpegs in after effects and its always 320*240
I cant seem to get a 352 * 288 result however I try.
The following spec is what clients ask me for -- I assume D1 shaped pixels but maybe I should ask them (...bound to cause LOTS of confusion their end
Format: MPEG-1
Video
frame rate: 25fps
Bitrate: 3000kbps
Audio:
Stereo - Layer-2
Sampling Frequency: 44100Hz
Bitrate: 256kbps
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
Noise around the edges.
By MaiOns in forum Newbie / General discussionsReplies: 8Last Post: 14th Mar 2010, 10:52 -
How do you crop off the edges of an mpeg file?
By True Colors in forum EditingReplies: 3Last Post: 11th Dec 2009, 13:04 -
Jagged edges on buttons
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 21st Oct 2009, 11:40 -
VLC + mpeg-1 = black screen?
By davecc in forum MacReplies: 7Last Post: 26th Jun 2009, 08:43
