I've bought a Denon DHT m330DV with region code 2. Now I want a Multi-region. I tried to use Region code which is posted on your site but no sucсess. Cuold you send me correct values for 12 XX, 13 XX and 14 XX to make dvd region free.
Thanks in advance.
Region Free for an PAL TV
1. Turn the unit on.
2. Press the “OPEN/CLOSE” button and open the tray.
(Keep the tray open during the setting.)
3. Press “CLEAR” “1” “4” “7” “0” “CLEAR” - “TEST MODE” will appear on the display.
4. Press the “▲”cursor key and “00 XX” (XX=this will be a numerical value) will appear on the display. The first two digits are incremented by one, every time you
press “▲”
5. Press the “▲”cursor key until you see 12 XX (default is 24) on the display. Press “3” "3” on the remote then the “ENTER” button
6. Press the “▲” cursor key again and you will see 13 XX (default is 23). If it does not say “33”, Press “3” “3” on the remote and then the “ENTER”
button
7. Press the “▲” cursor key again and you will see 14 XX default is 01). Press “0” “0” on the remote and then the “ENTER” button.
8. Press “RETURN”
9. Press “CLEAR” twice
10. Press “RETURN” (END should appear on the display)
11. Press the “OPEN/CLOSE” button to close the tray.
Region Free Denon dvd 1000
By jhasty1210 in forum Newbie / General discussionsReplies: 3Last Post: 29th Dec 2014, 08:31 -
Denon DBP-1611UD multi-region DVD player giving puzzling message onscreen
By outfoxed in forum DVD & Blu-ray PlayersReplies: 7Last Post: 20th Aug 2011, 03:39 -
Denon DVD-1940CI multi hack please :)
By talla in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Jul 2009, 12:32 -
denon 102 region free hack wanted
By CODEWERKX in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Jan 2008, 12:21 -
region-free code/firmware for DENON 1740
By abraxox in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Nov 2007, 15:05
