  1. The movie star software works fine at first but then locks up at different point when record from a dvd. My computer is a dell dimension 800Mhz,128Ram, 20gig hard drive,RCA dvd, Dazzle video creator II.
  2. Try TWNH [That Will Never Happen]
    A LOT of people on Dazzle DVC II boards say that this piece of software is a godsend. Never kept my DVC II long enough to try this program out, but so many people live and die by this thing.
    It uses less resources than MovieStar and can capture to MPEG segments, if you're on a FAT32 partition. If you're on NTFS then this feature is pretty useless.
    This program works off of the last saved settings from MovieStar, so before you use this program. Create a capture profile set to your liking, close MovieStar and then start this program up.
    http://stop.at/TWNH
