  1. Member Nzero420's Avatar
    Jan 2007
    I'm looking to convert MP4 to WMV I tired a couple of programs and work arounds that i've found on the fourms with no luck(They crash or freeze on me). the last thing I tired was https://forum.videohelp.com/viewtopic.php?t=284288 the encoder I used was WME.
    The reason i want to go to wmv is I want to start putting them on my HDD and stream them to my TV. The only wayi can at the moment is through my 360. any help would be appreciated.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    well have you tried windows movie maker? It's pretty flexible.
    Also try super - it can do a lot of conversions I just don't know if it will output to wmv. Worth a look though.
  3. Member Nzero420's Avatar
    Jan 2007
    I tried Super and any output i tried to use came up with a error. Windows Movie Make wouldn't even open the MP4 file or the AviSynth Script file. Is it something I'm doing wrong(which I'm sure it is because I'm a noob to all of this)?
    Right now this is how i got to where I am:
    - I use DVD Decrypter to get VOB files
    - Then I used Nero recode to get MP4 file
    If anyone has a suggestion for a different way for me to get to the point I'm at now or anything at all I'm open to try anything at this point.
    Apr 2004
    Miskatonic U
    Have you upgraded SUPER recently ?
    Have you tried using WME or SUPER on your VOBs instead of needlessly converting to mp4 along the way ?
    If you want to edit first, I would suggest you get an mpeg editor such as videoredo or womble, or convert them to an edit friendly form, such as DV avi, so you can edit in WMM.
    Read my blog here.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you tried stream the dvd using Tversity or Transcode 360(only for MCE)? THey will reconvert to wmv format and stream in realtime.
    Or use AutoMKV and make WMV directly from the DVD, see my basic guide, https://forum.videohelp.com/viewtopic.php?t=319304
  6. Member Nzero420's Avatar
    Jan 2007
    I tried to get automkv, but all I got was a changlog.txt
  7. Member Nzero420's Avatar
    Jan 2007
    I have tired theses two guides.
    https://forum.videohelp.com/viewtopic.php?t=221896
    http://www.bobsomers.com/articles/encoding-dvds-to-high-quality-movie-files-with-xvid-and-ac3-1/
    With both when I go to load .d2v, or the avs files I get errors. Ihave gone back through both of them and can'tfind what i'm doing wrong.
