  1. I've used both DVD Lab and Lab Pro with no probs, and I just tried the DVD LabPro 2 and everything is basically the same but I noticed a few changes, when I make menus and make the DVD and when I'm watching it and try to select a spot on the DVD to watch in the menu, nothing comes up..I never had this prob with the other 2 versions, does anyone know how I can fix this?
    Apr 2004
    Miskatonic U
    Are you running this latest version of DLP2 (2.24) ?
    What was your source video ?
    How did you create it ?
    Did you know you can run 1.6 and 2.2 on the same machine ?
    Can you be clearer in description of the problem ?
    I read it as being you have created a DVD with menus etc, however if you try to jump to a specific chapter during playback, you can't.
    Is this correct ?
    Are you using a scene selection menu, or the Next button ?
    Are your chapters true chapters, or have you slung a list of separate titles together instead ?
    Read my blog here.
  3. I got it fixed somehow, I'm not sure how I did but everything seems to be working now...no i didnt know u could run 1.6 and the new one at the same time, how can you do that? I tried to find an older version of it before I got the prob fixed but I couldn't find it anywhere, I'm not too crazy about the newer one
    Apr 2004
    Miskatonic U
    I haven't had any problems with 2.2 yet, thankfully. Just install 1.6 into a different folder and use your original registration code.
    Read my blog here.
