    Jan 2007
    I have the latest version of the software, it encodes the picture perfectly, just tells me on Realplayer some portions of the file cannot be played do I want to search for an update, which it says none can be found.
    Im using default settings for AutoGK.
    What I have noticed though, is its only DVD9 encodes where the problem lies, if I encode from a DVD5 it works perfectly.
    Though even if I rip the DVD9 to DVD5 and encode I get the same problem, and its on each DVD9 disc I tried, as I said all DVD5 encodes do work, so im confused.
    do you get same problem if you play with something else like vlc that has all codecs built in ?
    Jan 2007
    Havent tried yet, only tried WMP, WinDVD and Realplayer so far, ill try VLC quick.
    Jan 2007
    Well whatdya know it works! weird, what could it be?
    Is it a codec problem?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yup - If VLC works but other AVI players don't, it's 99.9% certain it's a codec prob
    /Mats
    Jan 2007
    I still find it strange though that DVD5 encodes play on Realplayer, but any DVD9 ones wont, maybe theres a glitch on AutoGK somewhere, grrr, anyway at least its not huge, I mean its like the 5th time I have encoded it, so I was worried it was my discs!
