hey... when i record something in uncompressed and i put the videofile(40gb-70gb) @ the program to edit (sony vegas) or when i try to see @ winwamp my pc rebbots![]()
Results 1 to 9 of 9
# Choose a subject that describes your topic. Do not use subjects like Help me!!! or only Problems. . Click on the edit-button to change the subject.
What's winwamp?
Try to cut those big files in several parts for editing. -
Use Virtualdub to cut those big files into approximately 2 hours length. Here is how to do it
https://www.videohelp.com/guides.php?guideid=357#357
https://www.videohelp.com/guides.php?guideid=115#115
More Virtualdub guides here:
https://www.videohelp.com/tools?tool=Virtualdub
Then try to load those smaller files into Vegas for editing.
Do not use Winamp for video preview.
Use any of VLC, MPC, KMPlayer, GOM player...all freeware. -
yeah! i did that but when im doing the final stage "Save as AVI" a few minutes next it appears a msg that says: The windows couldnt save all files into the G:\$Mft. The files where lost. This error happened because a hardware error of your computere or a network connection. Try to save the file in other place" but i cant save @ other place cuz i dont hv space on the hdd
Your pc specs show's two hard drive's ... I suspect you have been trying to split and save the file without using some form of video / audio compression in vdub , to the same drive the original clip is currently stored , which is why your running into this current problem .
You have to remember that the system preserve's a particular amount of drive space for some feature's ... the swap file space , recycle bin , and restore point .
You could trim back the default recycle bin ... it's most likely stuck on system default equal to around 10% of the drive's maximum partition space ... and use some form of compression when using vdub ... if you want to use sony product ... double check on what it support's as input ... you wouldn't want to compress the clip into a codec that it dosent , or has issue's with ... now would you .
Not forgetting , you should possibly be sending and storing the edit's on the second drive ... space permitting of course . -
I think he's telling you, you're running out of Hard Drive real estate, (space)...Originally Posted by bestA
with possible reasons why, and giving some methods of reclaiming some of it.
Also, maybe try saving that vid to some "Lossless" codec too.The Devil`s always.....in the Details!
How to extract subtitle from videofile AVI
By Andrey81 in forum SubtitleReplies: 6Last Post: 17th Feb 2013, 13:54 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
Videofile to DVD interlace problem
By tekMedia in forum Video ConversionReplies: 3Last Post: 18th Jun 2010, 06:30 -
Unable to transfer a videofile from a digital camera to my PC
By alegator in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2009, 13:01 -
split videofile controlled by datecode
By bjolen in forum EditingReplies: 0Last Post: 22nd Nov 2009, 10:48
