is there any software that can read the flags set in an ac-3 stream?
if you mean the actual picture representation of the sound wav you would need to rip the ac3 to the computer. Then you could rip it to six seperate wav files using besweet. From there you can use any audio editor to read the individual channels and look at the actual wav file.
Now as for exactly which "flag set" you are referring to you will need to be more specific.
Perhaps you mean the "chapters"???Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
sorry i meant the DRC flag and copyright flags. I wanted to see how my dvd recorder sets the flags in the audio it makes.
Sonic Foundry's Soft Encode would show you all the flags in an AC3 stream.
But it's quite an old and obscure program (and no longer commercially available).
You might check if the latest version of Sound Forge (now owned by Sony) can handle AC3. It might give that info then. -
sound forge only exports dolby digital it cant import it at least in raw stream form
Dolby Digital 5.1 track?
By dstrahan in forum DVD RippingReplies: 1Last Post: 24th Jul 2011, 23:48 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 15:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
