i have apollo psp video converter and it converts fine but i need to convert an already mp4 too a mp4 to change the resolutions and the volume. however apollo doesnt let you convert mp4's. is there a way around this or do you recommend another program. i tried pspvideo9 and 3gp but they are too slow for my computer.
i need something that tells you the file size before and is speedy.
thanks.
You could try Nero Recode... not sure if they will accept a mp4 as a source
I think gui4ffmpeg (free) qualifies although I don't think it can adjust audio volume (or did you mean bitrate or file size by "volume"?). Post back here if you try it and have questions or problems. It's a very quick download and an easy install, i.e., you won't lose much time by trying it (and no money).Originally Posted by zinc
try super, its fast , it will NOT predict the file size
http://www.erightsoft.net/S6Kg1.html
ffmpegX to PSP conversion creates unreadable, Zero KB files
By Peter Sarkisian in forum ffmpegX general discussionReplies: 5Last Post: 15th Feb 2010, 12:06 -
PSP(MP4) Video Conversion...
By Nizomi in forum Newbie / General discussionsReplies: 7Last Post: 11th Oct 2008, 04:53 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
Easy GUI Conversion from Avi 2 MP4 for your video iPod or PSP
By qwerty9876543 in forum LinuxReplies: 2Last Post: 3rd Feb 2008, 11:17 -
Conversion tool for PSP
By marcopolo1 in forum Portable VideoReplies: 2Last Post: 8th Sep 2007, 13:07
