...but after 15 minutes of floundering around a bunch of windows, could not figure out how to do it.
I thought this sight might be a good place to get people at other A/V sites to place their media experiences (we need to have a single site for this!).
However, after seeing how it was impossible for me to figure out how to do it, there doesn't seem like there is much point to suggesting this site.
I am very disappointed because I think, overall, this is a very good site!
Regards,
Tom
Sorry you are disappointed. I didn't see where it was all that complicated. It's all on one page. You just find your recorder and click 'Add report or comment'. We make it like that to reduce spamming, which is a major problem on a site like ours.
And this post would more likely be read by our DVD Recorder Mod in the feedback forum. Moving you. -
You can add dvd media comments in the dvd media list and link/report that it works good with your toshiba recorder but you would have to report one media at a time. You can't use the dvd recorder list comment and "link" to media from dvd media list yet...
Or do you want something else? -
I guess my point about the method is not intuitive is sort of demonstrated by the 2 replies I receive - and I want to stress that I am very grateful for members taking the time out to try to help me.
I looked into some of those suggestions and the it is interesting that it appears that when you go to the page about the particular recorder you have, where they list the media people have used, there is a link "Add your DVD Media Comments Here" which is clearly the obvious place to start clicking.
What is really interesting is that entering there and failing, I never found the page resulting from clicking on "Add Report of Comment"
While ARoC is quite thorough, it is not clear how to add a particular media experience - it appears that you merely discuss it rather than add to the "DVD Media Comments for this Recorder."
I would suggest that when you click on AYDMCH, you should get a little form to fill out where you select the media type with a checkmark, a pulldown list for the retailer, pulldown list for the manufacturer, and a pulldown list for the media ID code, and then numeric input for # burns, # fails, etc.
I believe the problem is that the organization is by media, not a particular model recorder.
I think that is backwards.
When you buy a recorder, you are interested in everything regarding that recorder.
I would further suggest that you do not get many additions to the "DVD Media Comments..." because people try and give up when things just don't make any sense.
I know that your site does not have any usefull media information regarding the Toshiba RD-XS32 which is quite unfortunate.
There may be bigger and better sights for this type of databasing, but I don't know of any which is not to say that I have look extensively. While I will be trying to find the best web site to see what success people are having with media in this recorder, it may turn out that your site is the best.
But even if it is, you must make it easy and intuitive to add a media experience for a particular recorder. -
I could try to add something like that. Thanks for the idea.Originally Posted by MrCreosote
Baldrick,
Sorry for the delay, I was having trouble with inactive and pw's...
I think a simple window there would be very intuitive.
Would you be able to populate the DVD Media tables also from input via this new window?
I suppose to be thorough, there would have to be "other" options for new media and media codes.
Tom -
I will try keep it simple and also add it to the dvd writers form.
And yes I will use the media from the dvd media list. If you want to add a new media you probably have to use the complex dvd media form, https://www.videohelp.com/dvdmediaform.php?addnewmedia=1 ...mainly to avoid duplicates and spam.
DVD Recorder Wish list
By Ozzyjim in forum DVD & Blu-ray RecordersReplies: 17Last Post: 27th Jul 2010, 07:36 -
New FCC site - Enter address> possible station list and predicted streng
By edDV in forum Latest Video NewsReplies: 4Last Post: 18th Feb 2009, 00:21 -
DVD Recorder list
By loster in forum FeedbackReplies: 13Last Post: 1st Mar 2008, 12:23 -
How Can I Add The Name Of My Site To A Video
By marnisper in forum Newbie / General discussionsReplies: 19Last Post: 25th Feb 2008, 15:31 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
