ok so i am using dvd shrink and im copying the movie and cutting out all the extras and menus im using dvd shrink v 3.2 and what i was wondering when i click re-author under "main movie" it says title 1 and than below it says title 2 both the same size and both the same duration.
what is that all about?
one version of the title could be in widescreen and the other in fullscreen.
You can preview them in Shrink, but if you still can't tell any difference, I usually 'roll the dice' and pick Title 1. That should be the right one the vast majority of the time, at least with most US DVDs.
yeah i know.. thats exactly what i thought.. just thought i would put apost up to see if anyone knew any diff.
thanks though -
for instance the movie is cars the version of the original i had bought was widescreen there is no option on the mainu of the original disc to play it in full screen or widescreen but yet it shows title 1 and title2
Sounds as though another pesky multi angle vst has appeared ... keep them coming .
DO NOT ... use dvdshrink on these before you have corrected the problem before hand ... I am telling you will stuff it up .
It's game over if you dont have the original disk if you have already done this ... cause while I can fix it , you have already lost so much bitrate in the video ... and possibly combined the two together ... it's so screwed up ... only a season'd fruit basket like myself could pull it apart and rebuild it .
Load the dvd in pgcedit , let it finish the scan , then double click on the title that show's the problem to bring up the chapter list window .
Smack bang down below , to the left of center is "del angle's"
... man , I may have been going the long way about this .
Pick the angle that is not required ... it's not the first 1 ... but dont hold my word on that because you know what's going to happen next by the producer's ... that's right ... they'll do thing's my way ... and you'll have to go the long way round .
There's spy's around here you know
Now , what was the question ... that's right ... I think it said del or move it in the next box ... move it is safer (for me its aka the sod) .
Now save dvd and play it back ... if all is well , go to where the dvd was saved to , and delete the pgcedit folder before you burn it to dvd .
Or tinker it down , now with dvdshrink ... it wont screw up this time round . -
In simple term's you say ... well here's a cut down version .
1: Load the dvd in pgcedit .
2: Let it finish the scan , then close the box , leaving pgcedit with the loaded dvd .
3: Then locate the main title (it will display time playback length of main title) .
4: Double click on the title (the one with issue) .
5: Down below in the new window that has appeared will be a button with "del angle's" .
6: Pick the angle that is not required ... (normally it's the second one).
7: Next box has "move" or "del" option's ... best to "move" it (safer) .
8: Now save dvd .
9: Play it back .
10: If all is well go to where the dvd was saved too .
11: Delete the pgcedit folder hiding here .
12: Burn the remaining content to dvd .
Use dvdshrink to shrink a little if required prior to burn .
Few dvd's released use various screw up trick's where dual title appear's ... "up the creek" is a good example ...
One real movie title with a second angle of junk ... one too learn from .
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
