Results 1 to 9 of 9
    Jan 2007
    I NEED HELP SELECTING THE CORRECT VOB FILES TO MERGE TOGETHER SO I HAVE ONE BIG VOB FILE. AFTER THAT I NEED TO CONVERT TO AVI FORMAT TO MAKE THE FILE SMALLER. SOMEONE PLEASE GIVE ME A FEW TIPS TO START. Which of these files should i choose????? I am open to any suggestion or help i can take please
    THANK YOU.
    VIDEO_TS
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VTS_01_0
    VTS_01_0.BUP
    VTS_01_0.IFO
    VTS_01_1
    VTS_02_0
    VTS_02_0.BUP
    VTS_02_0.IFO
    VTS_02_1
    VTS_03_0
    VTS_03_0.BUP
    VTS_03_0.IFO
    VTS_3_1
    VTS_4_0
    VTS_04_0.BUP
    VTS_04_0.IFO
    VTS_4_1
    VTS_4_2
    VTS_4_3
    VTS_4_4
    VTS_4_5
    VTS_4_6
    VTS_5_0
    VTS_05_0.BUP
    VTS_05_0.IFO
    VTS_05_1
    VTS_05_2
    VTS_06_0
    VTS_06_0.BUP
    VTS_06_0.IFO
    VTS_06_1
    VTS_07_0
    VTS_07_0.BUP
    VTS_07_0.IFO
    VTS_07_1
    VTS_08_0
    VTS_08_0.BUP
    VTS_08_0.IFO
    VTS_08_1
    VTS_09_0
    VTS_09_0.BUP
    VTS_09_0.IFO
    VTS_09_1
    USA
    If the VOB files are part of a DVD, just use VOB2MPG to save them out as one MPEG file. Or an easier way is to use a program like FairUse Wizard to select the proper files and convert to Xvid or Divx in one step.
    If you just have the VOBS, you can view them with VLC media player or other players and choose the ones you want. In general the first fullsize VOB of about 1GB is usually the first one in the set and the rest are numbered sequentially up to 4 or 5. The last one in the series will be smaller.
    And by the way, MPLSDEUCE, typing in ALL CAPS is considered shouting on a forum and in poor taste and will not get you many answers, just complaints.
    And welcome to our forums.
    Jan 2007
    i am still a little confused on what files to choose when i convert to mpeg????
  4. Mod Neophyte redwudz's Avatar
    USA
    Since you seem to have all the DVD files, you might drop them into DVD Shrink and then reauthor the video to just the main movie. That DVD has more than the average structure, so you will generally need a program to separate out the main movie.
    DVD Decrypter can also work to pick the main movie. Look to the bottom of the DVD Decrypter toolpage for some guides: https://www.videohelp.com/tools?tool=DVD_Decrypter
    Here's a guide for DVD to Divx with the freeware AutoGK: http://www.rita.lt/guides/AutoGK_DVDtoAVI.htm
    Or using VirtualDub and other free tools: http://w1.312.telia.com/~u31220486/dvd2avi/dvd2avi.htm
    Jan 2007
    Thanks alot for the help i'll try that and write back
    Jan 2007
    Ok i have the main movie files. How can i get all the vob.files to covert to avi all at once or must i do it one at a time. I have a program that combines vob files but i am not sure which ones to combine? I have virtualdubMPEG and dvdtoavi. What know???
    VIDEO_TS.BUP
    VIDEO_TS.IFO
    VTS_01_0.BUP
    VTS_01_0.IFO
    VTS_01_1
    VTS_01_2
    VTS_01_3
    VTS_01_4
    VTS_01_5
    Jan 2007
    Viirtual dub mpeg2 keeps saying Error ititalizing audio stream compression check that the sampling rate and number of channels in the source is compatible with the selected compressed audio format i dont know what to do. can any one help????
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Get yourself AutoGK, and load the VTS_01_0.IFO file. It should do the rest for you with minimal input.
    If in doubt, Google it.
  9. Or rip your DVD with DVD Decrypter in IFO mode and set the "File Splitting" option to None. You'll get one big VOB file.
