so, when i have an avi with ac3 audio is always convert the audio to .wav with goldwave and stick it in tmpgenc for DVD creation. i've tried using the .ac3 as is, but i always run into synch issues, or incompatibilty... so i like .wav for quick n dirty DVD creation.
...anyway, when i convert .ac3 to .wav, then play the dvd on my tv, the audio is quiet and a bit staticky. what's the best way to solve this?
thanks in advance.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I normally just use the AC3 from the original file and put that in when authoring. But if you are having problems with that.....
You should be able to raise the volume level in Goldwave or in TMPGEnc encoder. The static noise seems to be a different problem. Have you checked the audio quality in each step of your process? Somewhere in there you must have a problem. -
Originally Posted by buzzinhornets
As far as dealing with the static, you can then import the new wav file into goldwave and use its filters.
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
Goldwave / AC3 problem
By andyellis in forum AudioReplies: 3Last Post: 29th Dec 2009, 23:27 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 04:57 -
Mixing AC3 and WAV on a DVD
By SCDVD in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2007, 00:33 -
goldwave and wav codec
By natty in forum Video ConversionReplies: 4Last Post: 15th Jun 2007, 07:57
