Okay so I have a .mkv file and when I try to load it in Virtual Dub Mod I get this error:
"Couldn't locate decompressor for format 'yyyy' (unknown).
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable. Only 'Direct stream copy' is available for this video."
I have been informed elsewhere that this error is caused by the Combined Community Codec Pack (CCCP) that I have downloaded to play videos. Can someone tell me how to fix this please?
Results 1 to 24 of 24
Jeez, that didn't work. Right now I am using mkvextractgui to do this but it says that the video format is this: (V_MPEG4/ISO/AVC) How can I convert this?
Okay, my video file has a variable framerate and so when I am able to extract it it ends up being almost one minute longer than normal. Can someone tell me how to fix this? I used avc2avi to turn the .h264 into an .avi in case that matters at all.
Hmm... when I try using the program it teels me to get .net framework. I have no idea what this is, could someone tell me what it is and where to download it?
It needs net 2. What do I download. Right now I'm on this page:
http://msdn2.microsoft.com/en-us/netframework/aa731542.aspx
There are a so many links and different versions, which do I choose. I have Windows XP BTW. -
Read my blog here.
How do I use this program? When I try to open a file it wants an .avs file. What is this and how do I get it?
All of that? Could someone give me an example of the avisynth script that I need. I tried doing it myself and I was actually able to open the file in virtual dub mod but it said it would take 49 days to encode it. D:
I obviously messed up here. I have an .mkv (.h264) with a vfr and I want to convert it into an AVI (preferably with XviD codec) What kind of script do I write? -
The Assumefps() will force a fixed framerate without altering any frames, so if you have true vfr then you may find strange speed changes. You may wish to drop this statement, or replace it with a Convertfps() instead. Set the actual framerate to match what the playback rate should be.DirectShowSource("{replace this bit with full path and filename}", false).Assumefps(23.976)Read my blog here.
Okay, just to update and make things clearer, this is my problem.
I want to convert my .mkv(V_MPEG4/ISO/AVC) *vfr* into an .avi(XviD)
1) I cannot extract the .avi from the .mkv that I have. The only thing that I am able to do it extract the .h264 using MKVExtractGUI which I have done.
2) My .avs files always have a problem. Even if I ignore the problem and try continuing regardless, my computer keeps bothering me about the YV12 codec which I am unable to install because apparently I do not have Quicktime 4.1.2.
3) I am able to use avc2avi to convert my .h264 into an .avi however my video becomes longer due to the vfr of my video.
4) You said that I need to use the .avi I extracted from my .mkv but when I get to this point, the video is already longer than it should be and I don't want it to get out of sync so I can't really use the .avi and even if I tried using it MeGUI would give me an error about the stupid YV12 codec.
Can someone help me? -
"mkv2vfr extracts all video frames from Matroska to a CFR AVI file and a timecode file. You can extract video to avi, process it with any apps and mux back to matroska using a timecode file if you didn't add/remove frames. If you changed the frames you'd need to edit the timecode file by hand"
http://haali.cs.msu.ru/mkv/MatroskaSplitter.exe
tc2cfr turns an avi file (with each frame present once) into a new avi file with null frames that has the specified framerate and varying display length for each individual frame based on a v1 or v2 timecode file.
tcConv performs v1<->v2 timecode file conversions.
http://web.missouri.edu/~kes25c/avi_tc_package.zip
__________________________________________________ _____________________
Install the Helix YUV codecs http://www.lillevold.com/files/yuvcodecs-1.2.exe
http://forum.doom9.org/showthread.php?t=89294&page=4 -
Thanks for the help people. I'll try something else though because this is getting too troublsome for me and I have other video problems for other files that I must deal with as well. I'll try this all again at another time.
Simple guide for Virtual Dub Mod 1.5.10.3
By s_joy09 in forum Newbie / General discussionsReplies: 35Last Post: 31st Jul 2010, 16:33 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 08:18 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 03:13 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
