Got a new camcorder. Old camcorder method was to play it through my ReplayTV, which created DVD-compliant MPEGs, then used VideoReDo to cut out small portions at beginning/end of each tape, bad fades, etc. Burned to DVD using ULead DVD Studio 3.0, added a few chapters, chose the picture I wanted for the thumbnail, etc. Nothing fancy.
I am not interested (yet) in video editing, fades, etc.
I just want something to put the AVI files that my Panasonic PV-GS250 creates onto a DVD in a decent format.
Will Sony Vegas Movie Studio be a good choice? The full blown Vegas 7.0 would be more than I'm looking for, I think.
ULead has several new versions out. Would that be better?
Thanks.
I've never used it, but ConvertxToDVD sounds like it will do what you want, is regularly recommended and is much cheaper than Vegas Movie Studio.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Try them, they have free trials.ULead has several new versions out.
Need advice to make my own home video/DVD
By Vidnewbie1 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2010, 13:30 -
seeking video conversion/burning advice/input
By fergwannville in forum Newbie / General discussionsReplies: 1Last Post: 9th Dec 2008, 15:51 -
changing aspect ratio of home video before burning
By bec in forum Authoring (DVD)Replies: 3Last Post: 8th Jul 2008, 13:54 -
Need Advice for Video Conversion PLZ
By unknown7 in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 22:22 -
Asking advice about HARDWARE for VHS VIDEO conversion projects
By perniente in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2007, 19:05
