Anyone know of a program that can run thru a video and automatically make screen captures from it?
Results 1 to 16 of 16
I Use this.
Must have Pro Version.
Open Movie.
File-->Export-->Movie to Image Sequence.
Set export fps to match movie's fps
to capture a "play by second" or,
adjust to a longer ( say triple the fps)
to capture in a "slideshow" type feel.
select type of file ( png or jpg)
Target to Folder
click ok.
If necessary stitch in Photoshop to make one huge Page of
all images, using the "Automate-->Contact Sheet II" command."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Awesome indeed.Originally Posted by terryj
One question regarding Photoshop "Automate-->Contact Sheet II" command:
Is there a way that Photoshop would preserve the original size of these captures? When i tried that command i always ended up in very small thumbs on my contact sheet.
Screen Grabber has one big advantage over the the Quicktime approach: it can display time stamp info. OTOH i haven't found a way to make it capture less than every 3 secs (that way you're ending up with tons of pics when giving it a longer movie). Or did i miss something?Originally Posted by headless chicken
*edit* Found it myself. Playing with 'Grid size' allows a slower pace of capturing -
With the Photoshop "Contact Sheet II" command Open BEFOREOriginally Posted by panhype
running the command on the Folder of Images:
change your target sizes to match your original size here."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Thanks for the help. Didn't get in the first place that with "Document" your output file is meant. So when you have 20 640x480 pixels captures and want to place these in 2 columns, then the "Document" size must be set to 1280x4800 pixels (just an example).Originally Posted by terryj
graphic converter can also make contact sheets and it's much cheaper than photoslop
Well, both ScreenGrabber and ScreenCapper have serious problems with FLV, MKV, WMV, etc. ScreenGrabber creates a maximum width image of 640, while ScreenCapper doesn't include any track or title info.
Had forgotten that old standby.
Although, I still need an easy way to get the video frames to start with. -
M-O, go back to the other thread, I commented in the one you originally started.
Urban Mac User -
If you want to extract the pictures and make a contact sheet in only one very simple step, there is a tool called Movie Tiler. Try it at http://www.mrose.nl/movietiler
HTH
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
Problems opening mkv to make screen caps with frameshots
By Wizard23 in forum ComputerReplies: 3Last Post: 15th Feb 2010, 17:16 -
Whats the best software to use to produce Screen Caps/Grabs ?
By maduncledai in forum Newbie / General discussionsReplies: 10Last Post: 26th Oct 2009, 20:38 -
Window doing full and and small screen[maximizing auto] prob
By vipertongn in forum ComputerReplies: 1Last Post: 12th Sep 2007, 02:06 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 12:48
It wasn't that spectacular to begin with.
