I've captured 6 vhs tapes with my dazzle converter which captures them as MPEG2. All six of them have authored perfectly in TMPGENC DVD Author. No this one captured the same way, TDA gives an illegal file error, saying that it isn't MPEG1 or MPEG2. But, when i check it in Gspot it says that it is MPEG2.
I've even tried uninstalling and installing TDA again but still the error. what's up?
Results 1 to 10 of 10
Get a more recent version of GSpot (2.52 Beta or later) - this version can't get any info from MPG at all (see all those n.a?).
No wonder all mpg info looks the same to you...
/Mats -
i've got gspot 2.6 also and it has them all listed the same - MPEG2. so i don't know what happened. i guess i'll try capturing it again and try, but the capturing process went fine and just like it always had so i don't think that would be the problem.
Here's the new version screenshot, just so you can see...
i just don't understand why TDA says that it is not an MPEG2 when it clearly is. -
Looks like a good enough NTSC DVD source material to me...
TDA shouldn't have anything to complain about AFAICS.
/Mats -
well... it is, so what does that mean?Originally Posted by mats.hogberg
I've had this problem beofre with TDA and it was because the resulting bitrate was too high! For some reason TDA doesn't like the combined bitrate for the audiio and video to exceed 8000. I noted that the Gspot screenshot says 10000. Try lowering it to 8000 or 7999 as the average (if you can do that in your capture). If you are capturing from tape or analog TV then going above 8000 won't be any different quality-wise anyway.
Relayerman
File output issue from TMPEnc Author Works, VOBs -> single MPEG2
By aln688 in forum Video ConversionReplies: 4Last Post: 10th Apr 2010, 21:17 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
