Hi
Ive recently downloaded a 2.5 GIG Music Video that has been recorded in HD Format with the following settings: -
Width 1280 pixels
Height 720 pixels
Duration 00.55.36
Bit Rate 384kbps
Audio Format AC-3 ACM Codec
Video
Frame Rate 23 Frames/second
Video Sample Size 12 bit
Video Compression Xvid
Now i usually for all my AVI, WMV conversion to DVD use WinAVi which i think is a great bit of kit and have had great results when transferring to DVD. Unfortunately i have tried converting this through WINAVI and as soon as it attempts to begin the software crashes
Now i then looked into XVID and there was an XVID converter which was available to try, i downloaded and when i attempted to convert it told me i didnt have the correct AC3 filter installed on my PC once i had located and installed that the XVID converter (which i was simply using to test the file) began to work - i then thought do i really need to xvid to convert it? what would the output file be? and now ive installed the AC3 filter would WinAvi also do the same and allow me to convert so i could put this music file onto a DVD - i stopped the Xvid converter (it was a trial so no doubt it would complete then have "Xvid Trial" or something across the screen), i then went back to Winavi and the same thing happened.(
now ive got this music video and 2 other film that do this in win avi so thought it was about time i asked why this keeps happening)
the other filmes are: -
Width 520 pixels
Height 274 pixels
Duration 01.38.36
Bit Rate 160kbps
Video
Frame Rate 25 Frames/second
Data Rate 120 kbps
AND
Width 480 pixels
Height 336 pixels
Duration 01.28.55
Bit Rate 192kbps
Video
Data Rate 134kbps
Now i dont know if this is a codec issue seeing as there all copied using the AC-3 ACM Codec, a recording issue, a HD issue etc but if you could shed come light on what i have to do to get this converted and onto DVD that would be greatly appreciated
I await your swift response
Regards
Richard
You could try a different tool such as Tmpgenc or Convertx2DVD.
I haven't used WinAVI, so I can't comment on how or if it can be "fixed".Google is your Friend -
I dabbled with WinAVI a long time ago, and found it to be low quality, unstable and all around crap. Everything I have seen posted here has validated that initial impression of it.
If you want to persist in using it, I suggest you raise your problems with WinAVI support. Chances are they will refer you back here, because frankly their support staff are about as good as their product.
Once you are sick of getting nowhere with them, either give ConvertXtoDVD a try, or learn how to encode and author manually. You will be surprised at how much better your results will be.Read my blog here.
Problem with Mp4cam2avi converting to XviD AVI
By twister6 in forum Video ConversionReplies: 11Last Post: 25th Jun 2010, 01:09 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 08:23 -
Converting .Xvid to DVD.... Please
By Galosat in forum Authoring (DVD)Replies: 2Last Post: 18th Sep 2007, 15:10 -
Converting from DVD to XVID
By morphjk in forum DVD RippingReplies: 11Last Post: 23rd Jul 2007, 16:33 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 1st Jun 2007, 23:40
