I haven't gotten any DVD+RW discs to work on this player yet it says its compatible.
I've authored a DVD using:
MyDvd
DVDit
Spruce Up
ReelDVD
and Ulead's DVD Movie Factory
using Memorex and Sony DVD+RW discs and im getting a NO Disc error
yet when I put the authored DVD+RW disc in my DVD-rom drive, it plays fine (so i know the authoring went okay).
Anyone know if there is a list of "compatible" brands of media? or if its just hte player and its not really compatible with DVD+RW discs? If its not then we need to update the DVD Player list to say so.
To my knowledge the Apex660 only supports DVD-R and not DVD+RW. A Firmware upgrade of the drive won't help you either.
then why does
vcdhelp.com list hte player as being DVD+RW compatible
and
http://www.dvdplusrw.org/video/compatibilitylist.html
list it as being DVD+RW compatible?
Wish they would give more information as to WHAT DVD+RW discs work and what programs they used to author if they are going to list it as being compatible.
<font size=-1>[ This Message was edited by: WizyWyg on 2002-01-17 01:57:38 ]</font> -
report and say that it doesnt work then...and mention what brand and what tool you used.
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Pioneer 660 HDD Recorder First Impression
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 26th May 2008, 21:20 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 12:33
