Hello Folks
I have created many DVD's, however Ithey have been arounf the 2 GB size. When compiling these- they work fine.
Now however I am creating a DVD at 3.95GB, using the same techniques used in the smaller dvds.
When compiling--- The end folder has the Audio and Video folders >>yet the compiling process says at the end - it is done! with no error pop up messages
the audio is empty (as it should be)
the video folder has only VOB Files.
I am at a loss as to what to do- I have contacted Media Enhance but they don't seem to want to reply.
I'm thinking the problem lies in Hard drive space- maby I don't have enough, or when creating many motion menus, it seems to stuff up the process.
I have created DVD's before- this is the largest which doesn't seem to work.
Alternatively- is their a way of creating IFO & BUP files for a bunch of VOB Files- I'm just thinking out loud- I'm not sure if this would work.
Thank you in advance
David Welzman
Magician
Results 1 to 18 of 18
You can use IFOEdit to create the missing files, however this will only help if you can be certain that the VOBs are complete. At this stage I doubt you can do that.
A couple of things come to mind, as do a couple of questions. Questions first.
1. What was the source ?
2. How was it created ?
DLP can be very picky about the quality of the source. It prefers elementary streams, so you should demux before importing your assets if possible, otherwise do so when DLP prompts. This may be an issue if you are short on disc space. DLP hates poorly encoded AC3 audio. All of these things can lead to incomplete compiles.
Finally, upgrade to 1.6 - it's a free download at MediaChance.Read my blog here.
Originally Posted by Welzman
If you have FAT32,convert it to NTFS and try again -
Australia uses PAL not NTFS- so therefore I am restricted with regards to the above issue.
as for gun slinger
I too doubt that my files are complete.
what I have done as a substitute is to re do all my menus- they are only still menus not motion- and have reduced the number as I have had lots of auto action to different motion menus.
the videos and audio remain the same- the only difference between the two DVD's are
1: The motion menus have been replaced with still.
2: Their are less menus due to no Outo Action
3: Their are less photos in the slide show section
other than that the dvd's are the same.
I'm thinking the problem lies not in the contects of the DVD but in the size and number of components in the DVD.
I will try an upgrade to 1.6 to see if their is a change (I hope so)
Thank you for your quick responces- if there are any other people out there woth thoughts- I'd love to hear them.
cheers
David Welzman -
oops
spelling probs:
I'm thinking the problem lies not in the conten
and auto actionts of the DVD but in the size and number of components in the DVD. -
What are your system specs? And what are your settings for Virtual Memory? You might be running low on memory (either physical or virtual)
Regards,
George -
I'll check the virtual memory - I don't really know how to but I'll saech for it.
As for upgrading to 1.6- it doesn't seem to find the files on my hard drive to upgrade- but at the same time there are not any improvements on the compiling anyway.
I think I have found something
RAM = 512 mb
processor speed = 1988 MHz
virtual memory 512 -
Did you set it to 512, or are you letting Windows manage virtual memory? Either case, either let Windows manage it dynamically, or set it to triple the amount just to test if that was causing the problem. You can tweak later...Originally Posted by Welzman
Regards,
George -
OK upgraded to 1.6 and.....it didn't work.
512 is the way it came from the box
as for Ntfs OK I read it wrong
I am already on NTFS from the looks of things
i'm attemting to raise the 512 to 1536 (3times 512) I'll see how this goes
Cheers -
OK I have turned the virtua; memory to 1536 and...
It still doesn't work.
I have tested creating smaller DVD's and they work.
It is just that the large one with large motion menus doesn't seem to do it correctly
and Medienhance still hasn't replied---after a week. -
How large are your menus (combined)? There's a max size of 1gb for a menu vob. Also, how many total menus do you have in you project?Originally Posted by Welzman
Regards,
George -
I have 14 menus
the total size of all the menus is approx 604 MB
The DVD is a promotional DVD for my entertainment.
I have a Clients & Testimonials Menus that are in essence a single menu with text and links to the next testimonials>>they are motion.
each menu on average is between 7mb to 17mb and they run for approx 30 seconds each.
The larger 17mb menus are for the different shows and they have a faded slow motion video playing in the background
I also have links to the 6 different shows with their performance highlights, plus a slide show of photos
I'm stumped and running out of ideas- I even deleted allot of files to (an extra 10GB) but there was no change in result.
One thing I have noticed but I do not know how to change is the TEMP folder in the compile section
>>I have lots of GB on the drive- but it shows up as 400MB required yet in the PDF help file the temp file in one of the help images shows the temp file being as large as the project.
I hope that is understandable---is their any way of increasing the temp file???
thank you for staying with this post
Dave -
You change the location of the temp folder on the compile screen (Project -> Compile). You can't change how much space it needs, or where it points. DLP will work out the space requirements. If you are doing a full compile it will need a lot more than if you are doing a smart compile.
What happens if you do a test compile with dummy objects ? Does it produce a full DVD folder ?Read my blog here.
i will try a test compile.
forgive me
what is the differnce between a smart compile and a full compile
there is no mention of a "smart compile" in the pdf help file -
You are right. Smart Compile is a 2.x feature. If the changes are minimal, smart compile save you have to remux everything. 1.x did not have this feature.
In which case something is very much amiss if the temp file space is only 400MB. Pretty much every project I have created has needed at least 80% of the final size as temp space.
Are the source files elementary video and audio streams (separate audio and video files), programe streams (a combined video/audio file, probably with a .mpg extension) or VOB files ?Read my blog here.
they are seperate Audio and vidio files--there are no VOB files
the audio and video files were demued (if thats a word) upon entry.
For all those who suggest uninstalling and reinstalling- I have done this approx 5 times and to different particians to no effect.
Tried the test compile----same---only VOB Files
shortly I will upload an html report to my site for people to view and see if there is an error somewhere that I cannot see. -
OK Folks
here is the link to my DVD report
http://www.icentertainment.com/dvd/suoper.htm
it's a very basic DVD- just lots of different movies
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 19:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 15:58 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 14:31 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 23:55 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 05:46
