Have a DivX with 24fps... need to make it an SVCD, PAL or NTSC doesn't matter. The best choice I guess...
What do I do? I know I have read something about a Pulldown
function what's that cause I think I read the nuimber 24 and 23 in the same place... or can I just convert it with TMPGenc as usual and not think about this?
What do I do?
Thanx/
Lars -
You don't need to convert the framerate if your dvd player supports NTSC. Just encode it to NTSC-FILM, which is 24 fps (actually it's 23,976 fps) and your dvd player will play it in 30 fps NTSC on your television.
So the 24fps to 23.976 would not be a differeance of 0.024 fps /second?
Thanx/
Lars -
I've never done SVCD, but...
Don't you have to apply the 3:2 pulldown for SVCD? From what I understand, you encode at 23.967 frames, and you NEED to apply a 3:2 pulldown to it for it to play correctly on most players.
For VCD's thogh, you can have the 23.967 frames and be fine (it's supported for VCD)...
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 16:48 -
24fps HDV (NTSC) to 29.97fps DV (NTSC)
By vodnick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2008, 07:36
