Hi there,
I don't really get an error from muxman directly, but the muxing result isn't as it should be.
The details are:
1.- i have the dvd demuxed in a folder on the harddisk (using pgcdemx)
2.- i want to add subtitles to the dvd
3.- using subtitle creator i get the .sup file (as usual)
4.- in muxman i put the video/audio/subtitle file and import the chapters from celltimes file
5.- everything is set up correctly, as i always do.
6.- i press start and then get the muxed dvd in another folder, no errors or anything
7.- if i play the resulted dvd i only get a total time of 3 minutes, then it stops (this is the first chapter mark in celltimes file, btw)
8.- i got normal, expected results with other dvds, using same method
What could be wrong now?
Thnx for any opinions.
Results 1 to 1 of 1
Muxman ver 1.0.3 Error?
By kimis in forum Authoring (DVD)Replies: 0Last Post: 26th Dec 2010, 09:03 -
Editing Audio on a DVD and re-encoding (muxman gives an error)
By Hulkmanche in forum Authoring (DVD)Replies: 6Last Post: 23rd Apr 2009, 03:21 -
GUI for MuxMan error
By michcio in forum Authoring (DVD)Replies: 20Last Post: 16th Apr 2009, 09:06 -
GfD Muxman Error
By michcio in forum Authoring (DVD)Replies: 2Last Post: 14th Jan 2009, 13:11 -
MuxMan Error
By JConnor in forum Authoring (DVD)Replies: 24Last Post: 10th Jan 2009, 21:59
