    Feb 2006
    Steventon, United Kingdom
    A friend who is about up to my level of expertise has given me a box with Xpert DVD Maker USB 2.0 on the front of it. There is a device in it that allows one to connect a VHS player to a computer and two discs. The first one has DVD Maker USB 2.0 on it. The second has Cyber link Power Producer 2 on it. He suggested that I could use this software and hardware to play a VHS tape on the VHS player that is connected to the computer using the V-Stream device and that it could be captured on the computer where it could be edited using some editing software but all I can see when I open the software up is what appears to be the facility to copy files to DVDs and not to the computer.
  2. Member MysticE's Avatar
    Nov 2003
    Although I'm not familiar with either piece I'm sure you can do more than just burn staight to disc. Read the documentation.
