I have this problem.
I downloaded a video, and when I play it with WMP I listen to its two differetn languages (original and dubbed).
How can I turn off one or the other so to be able to listen to actually only one track?
Assuming you're using Windows, click on the "speaker" icon on the bottom of your screen. It should open a sound control. Shift the balance over to left or right to hear only the respective track.
I tried this already, but it stays the same... I keep on hearing the two languages on a single side too
Your video (what format is it? AVI?) has two separate audio streams in the same file. WMP needs a splitter installed to play the streams properly, like Haali's. Or use a different player like Media Player Classic, VLC, mplayer, etc.; those don't require an external splitter installed.
change audio language
By natty in forum Newbie / General discussionsReplies: 14Last Post: 1st Sep 2011, 08:07 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Change audio language
By mew1033 in forum Authoring (DVD)Replies: 7Last Post: 24th Dec 2009, 06:31 -
Dual Language Films
By Witchypoo in forum Newbie / General discussionsReplies: 6Last Post: 29th Jun 2008, 06:42 -
Help extracting language track from dual audio video.
By ebisoba in forum Video ConversionReplies: 5Last Post: 9th Sep 2007, 14:53
