So I've been trying to convert my vhs family movies to dvd's and so far I've been having a ton of problems. I either have a strange white line running through the video or constant flipping of the image. If I play the video it flips but once I rewind or fast foward it's steady.
How do I fix the problem or is their a place I could bring my video's and get them fixed?
thanks
You would need to explain the method, hardware and software you used before anyone could give you much more than a guess.
Oh its my friends machine. I just know its a vhs/dvd player all in one. :/
I have found that my VHS tapes that have not been played for a while that the tape has shifted and are binding in the cassette so I always fast forward and rewind at least once if not twice to reduce the binding. Then I find my captures are better with less glitches. Sometimes the signal has deteriorated to the point that no clean copy can be made.
You need to find out and tell us the make and model of the VHS/DVD unit you are using.
Digitizing family VHS movies - interlacing/quality issues on iMac 27"
By genkiness in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2010, 23:32 -
cant transfer,to dvd, old family vhs movies i had professionaly made
By axememan in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2009, 09:33 -
Simplest way to convert home VHS movies to DVD using VirtualDub?
By Pickngrin in forum Capturing and VCRReplies: 11Last Post: 21st Aug 2008, 09:32 -
Adding Audio to DVD family movies - more complex issues than it looks?
By steve8443 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 13:51 -
"FAMILY" editing dvd movies
By smcgil989907 in forum Newbie / General discussionsReplies: 11Last Post: 14th Jul 2007, 09:55
