When I try converting .avi or .asf divx movies into VCD or SVCD using TMPGEnc, the program just freezes after the first second or two. I read that this happens sometimes and that to fix the problem you should first convert the audio into a .wav file. I tried downloading other converting programs but most don't work with .asf and I received error messages with the .avi files as well. I just don't know what else to try.
So I downloaded VIRTUALDUB v1.3c with the SMR plugin and followed the instructions. But the file that I produced was NOT a .wav file....instead it was a file type which my computer didn't even recognize. I tried again following all the directions on how to use it on VCDHELP.com but it just wouldn't produce a .wav file.
So now i am stuck....what is the best and easiest way to convert my .avi and .asf divx files into MPEG-1 and MPEG-2?
Thanks![]()
so when you used virtualdub did you save the file as a .wav format ? i have a few asf files and i have used the virtualdub w/o any problems converting the audio
you probably didnt change the audo to full processing mode
but anyways.. frameserving is the best way to go imo... virtual dub handles compressed avis much better than tmpgenc.. when you frame serve to tmpgenc it basically sends a raw avi (a frame at a time) to tmpgenc...
http://www.vcdhelp.com/convert.htm#frameserve
follow instructions exactly
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
probelm converting .mov to .avi
By Derrydoc in forum Video ConversionReplies: 3Last Post: 28th May 2011, 17:10 -
Synchronization Probelm with Dolby Digital EX Audio, Help!!
By caesarhawy in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2009, 08:35 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 09:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
